2.56's With W-31 Type Powertrain?
Old October 19th, 2015, 10:24 AM
costpenn's Avatar
Building a 71 Supreme and going to do a 4 speed conversion. Here's what I am planning on finishing up with:
Engine:
'70 350 block - oversize yet unknown
W-31 pistons
#7 heads with big valves installed (engine currently has #6's)
406768 442 M/T cam
OE cast intake and exhaust manifolds
Carb and distributor built to W-31 specs
Trans:
M-21
Rear End
2.56 Limited Slip - the original rear end to the car and it is in great shape.
This car is going to be for fun - not any serious racing. I am also wanting it to be stock appearing, using the parts I have or will be gathering. Will this combination be OK with the 2.56's ?
costpenn is offline
Old October 19th, 2015, 10:46 AM
GEARMAN69's Avatar
Hell no to be blunt. It will be nearly un-driveable to take off from a stop. The worst 1st gear ratio trans (2.2) and a very high rear (2.56) designed solely for an automatic makes for a bad choice even with a stock cam it would be very pesky taking off from a stop sign. Just to be driveable at all you would need to bump up to a 3.08-3.23 gear at the very least if you kept that tranny and then it will still be a little tough. To keep the 2.56 gears the only way to really work is go with the good old formerly Doug Nash (Richmond 5 speed) the has a 3.28:1 1 st gear and a 1:1 5th (no OD) and not use the M21 http://www.summitracing.com/parts/rmg-7022726a
GEARMAN69 is offline
Old October 19th, 2015, 11:58 AM
Rocket Renegade!
Yes, with that combo you can expect to burn up a few clutches!
BangScreech4-4-2 is offline
Old October 19th, 2015, 12:31 PM
I wouldn't, I think those gears will take all the fun out of your fun build.
oldcutlass is online now
Old October 19th, 2015, 12:57 PM
RandyS's Avatar
Must agree with the gang, your gas mileage will be great, but it won't get out of it's own way.......
RandyS is offline
Old October 19th, 2015, 01:36 PM
+1. An ill wind blows...
MDchanic is offline
Old October 19th, 2015, 02:11 PM
Ryan 1969 Chevelle SS396's Avatar
I have been considering gears and trans combinations and like the idea of a Super T10 with 3.somthing first gear and 3.08 rear gears.....
Ryan 1969 Chevelle SS396 is offline
Old October 19th, 2015, 02:13 PM
71 cutlass convertible
lshlsh2's Avatar
It would be good for running on the salt flats. Street not so much.
lshlsh2 is offline
Old October 19th, 2015, 02:28 PM
GEARMAN69's Avatar
Yeah there is a light duty ST10 BW with lower gearing from a late 2nd gen F body 305 application that might work if you found one
Old October 19th, 2015, 04:21 PM
costpenn's Avatar
Thanks all. Will begin the hunt for a 3.08-3.23 posi carrier and 3.23 gears. At least it's not a 68-70 rear end!
costpenn is offline
Old October 19th, 2015, 04:23 PM
Rocket Renegade!
You'll be glad you did. You still might wanna swap that M-21 for an M-20 with the 2.52 low, though. I had a Camaro with a 3.55 Posi and an M-21. Powered by a Corvette 327/350 hp L-79, it still took a little clutch slippage to get it rolling off the line with any authority.
Last edited by BangScreech4-4-2; October 19th, 2015 at 04:28 PM. Reason: Additional info.
Old October 19th, 2015, 05:01 PM
GEARMAN69's Avatar
You can keep your 2 series posi unit and just a nice set of 80's-2000's GM 1500 series truck 3.08-3.42 gears and use a ring gear spacer.
Old October 19th, 2015, 05:02 PM
GEARMAN69's Avatar
The tallest gear used with a M21 from factory is around 3.55-3.73 on a Chevy normally besides 3.90-4.33 etc on a Pontiac 400 although my old 70 TA RAIII 400 was factory M21 3.55
Old October 19th, 2015, 07:11 PM
2blu442's Avatar
Years ago I had a 1968 Cutlass 350 with a M21 four speed. When I bought it there was a 3.08 under it and I felt like it leaped across the intersection... I couldn't ease off a dead stop. Money was tight at the time and I came up with a Chevy 3.31 that I swapped in. That was much more comfortable to drive. Then a car I sold and wish I had back was a 1972 442 350 4bbl and 4 speed with a 3.42 posi. That car was a kick in the pants to drive. From that experience I'd encourage you to consider the 3.42 ratio.
John
2blu442 is offline
Old October 19th, 2015, 07:38 PM
Let's be clear. The M21 and M22 are racing transmissions designed to keep the engine in a very narrow RPM band on the track. They SUCK on the street. Sell the trans and buy a T10 with the 2.88 first gear. You'll be MUCH happier. Better yet, get a five speed.
joe_padavano is offline
Old October 19th, 2015, 08:47 PM
oldsmobiledave's Avatar
Or
Or....ditch the transmission. You can keep the rear end & install a Richmond 5 speed which uses a 3.07 1st gear & a 1:1 5th gear. You will love it.
oldsmobiledave is offline
Old October 19th, 2015, 09:03 PM
costpenn's Avatar
Working on changing to a M-20. Looks like the tallest rear gear offered from the factory with a M-20 was 2.78 in '71. Guess I'm kind of Old Timey because I want to put a Muncie in it.
costpenn is offline
Old October 19th, 2015, 10:04 PM
Fyi
I think you meant 2.73 as 2.78 was in 1970 and only in Type O. Seriously the 5 speed can be had cheap as many are pulling for 6 speeds. They work well with power of mild SBO. The M-20 is nothing to get excited about but if you do get one get a 1971-1973 version.
Old October 19th, 2015, 11:20 PM
Rocket Renegade!
Good for you! Don't go restomod! It's a slippery slope -- first a 5-speed and before you know it, you're rockin' 22s with O-ring tires, a purple digital dash, videoscreens in your headrests, and a chrome steering wheel.
Old October 20th, 2015, 05:21 AM
GEARMAN69's Avatar
Just keep the M21 and do some 3.73's !
Old October 20th, 2015, 06:11 AM
no
NOT. Please put down the bong & step away from the key board.
He is converting an automatic equipped car over to a 3rd pedal car for fun; why not maximize the fun factor and make it driveable? His plan to run a close ratio 4 speed with a 2.56 diff was a path to failure. Not sure how you go from installing an extra gear to what you implied would happen.
Old October 20th, 2015, 06:37 AM
GEARMAN69's Avatar
This is easier and cheaper choice combined with a 3.08 you can drive easy off the start and cruise very well but catch enough rev's to help it get into the cam cruise range on the highway.
Old October 20th, 2015, 06:44 AM
RandyS's Avatar
Ahhhhhh, the good old days..........
RandyS is offline
costpenn's Avatar
If I had the bong, it might go all the way including the mural of 2Pac on the hood.
costpenn is offline
Old October 20th, 2015, 10:47 AM
Rocket Renegade!
Sorry -- should have put one of those little smiley dudes on that post to show that it was a joke.
Old October 20th, 2015, 02:49 PM
BlackGold's Avatar
Muncie = Cool.
For what it's worth, even the racers in Pure Stock find they like the M20 better than the M21 close-ratio. And by "like" I don't just mean it's easier to drive, it also performs better.
BlackGold is offline
Old October 20th, 2015, 03:43 PM
The PSMCDR guys can use M22W's heavy duty Muncies built with M20 gear spacing:-)
Old March 12th, 2017, 06:24 AM
Bfg
Bfg's Avatar
I converted my M-21 to a M-20 because I have a 3.23 rear gear. Just had to replace the cluster gear and the impute shaft. Anxious to see how it drives!
Bfg is offline
dads72
March 25th, 2015 08:09 PM
L77F85
Drivetrain/Differentials
16
November 29th, 2013 06:19 AM
Cuttyon22s
November 20th, 2006 06:07 PM
Edveen
July 22nd, 2006 12:15 AM
<rebelyel>
September 3rd, 2004 09:30 AM
Quick Reply: 2.56's With W-31 Type Powertrain?
