Power Steering
Power Steering
Restoring a 1972 Cutlass with 350.
Moved my power steering pump to opposite side of engine with newer bracket. Engine had A.C. pump. Removed A.C.
Started engine and fan blew power steering fluid all over engine. Power steering fluid was coming from cap as though there was too much pressure.
Ideas?
Ideas?
There are no Oldsmobile applications with the PS pump on the passenger side of the engine. ALL 1964-1990 Olds V8s mount the pump on the driver's side. Are you really talking about the POWER STEERING PUMP or the ALTERNATOR?
Actually, my point was that doing it isn't possible. I've never seen a bracket that mounts the PS pump on the passenger side of the engine - there is no logical reason to do it.
The fact that the O.P. hasn't been back to this thread since the first post tells me that he meant to write "alternator"...
Agreed about the PS bracket. The alternator being relocated makes sense with the statement about removing the AC, although I can't imagine why anyone would do that. Maybe it's because I live where summer temps are in the 110+ range...
Yes, I apologize.
Power steering pump always on drivers side.
Changed brackets only. I meant that since removal of A/C pump everything is on the drivers side of the engine.
nicks1966
January 12th, 2014 01:46 PM
KZ442
April 10th, 2009 03:16 AM
