1965 4sp. Crankshafts
Old March 23rd, 2014, 05:58 PM
Bfg
Bfg's Avatar
Was there a part number stamped on the crankshafts on the 65 olds cranks? If so what was the number for a stick crank? Thanks
Bfg is online now
Old March 24th, 2014, 04:01 AM
Run to Rund's Avatar
No, just a forging number. Easiest way to check if it is a stick shift crank is to look at the back end.
Run to Rund is offline
Old March 24th, 2014, 04:13 AM
Bfg
Bfg's Avatar
Was the forging number different from auto cranks and stick cranks?
Bfg is online now
Old March 24th, 2014, 06:25 AM
2blu442's Avatar
Nope. The manual transmission crank was the same, just drilled out for the pilot bearing. The 425 also used the same crankshaft. Since these are forged cranks you'll see the number as raised on one of the crank lobes. So if you need a manual transmission crankshaft for a project you can purchase a 1965-67 automatic transmission crank from a 400 or 425. Then have a competent machine shop cut it out for the pilot bearing or bushing if you prefer. I had this done a few years ago and the machine shop used a lathe to cut out the area for the pilot bearing. There's an old thread that has the specifics on what needs to be cut out. It worked out very well.
John
2blu442 is offline
507OLDS
April 28th, 2014 03:45 AM
dc2x4drvr
August 23rd, 2012 05:25 PM
BosMobile
July 24th, 2009 08:12 AM
Warhead
June 13th, 2009 10:23 PM
DaLump
February 14th, 2008 06:25 PM
Quick Reply: 1965 4sp. Crankshafts
