o2 sensors in older cars
Old December 5th, 2013, 07:04 AM
  #41
Mr. Johnson
rjohnson442's Avatar
I've seen a wideband a/f gauge that that's reads both heads on one gauge. (two needles) I can't remember who makes it though but once I find it again this is my next purchase. I've tuned with my butt and a vac gauge for long enough. Now I'd like to see what the real numbers are. What would be a good a/f ratio for a 455 and a 350? or stoich as they say.
rjohnson442 is offline
Old December 5th, 2013, 12:21 PM
  #42
cutlassefi's Avatar
Imo this is the coolest thing ever;
http://www.aemelectronics.com/wideba...gt-monitor-34/
And stoich is stoich, no matter what the application. As long as it's 100% fossil fuel it's 14.7:1.
cutlassefi is online now
Old December 5th, 2013, 05:55 PM
  #43
can66's Avatar
i'll have to agree that AEM makes good stuff but i'll just get the dash gauge.i'm glad i got some people thinking..should be interesting,prices for the gauges is around $200.if anybody has a good outlet,please let us know.thanks,paul..
can66 is offline
Old December 6th, 2013, 04:27 AM
  #44
chadman's Avatar
Here is where I got mine:
AEM 30-4100 UEGO Controller Gauge : Amazon.com : Automotive AEM 30-4100 UEGO Controller Gauge : Amazon.com : Automotive
chadman is offline
Old December 6th, 2013, 06:52 AM
  #45
Mr. Johnson
Found this one but I saw another one with numbers and not lights. That's the one I want but here's the idea. I suppose you could use two sensors with a switch and one gauge also.
http://www.jegs.com/i/Equus/390/8366...FcpDMgodHSAAvA
Old December 6th, 2013, 09:28 AM
  #46
chadman's Avatar
You definitely want one that has a digital readout. It makes it much easier to just read a number while driving.
chadman is offline
Old January 5th, 2014, 10:13 AM
  #47
KDV
KDV's Avatar
I want to do the same thing to a street '72 CS 350 with headers.
I intend to use a dual band air/fuel meter, most likely this one.
Any advice on the best place to cut the bungs into the headers? Toward the collector?
KDV is offline
Old January 5th, 2014, 11:10 AM
  #48
Mr Nick's Avatar
As close to the header collector as possible, mine is mounted in the collector itself. You should also try to have it angled slightly down (end of the sensor with the wires higher) so any condensation in the pipes drips off the end of the 02 sensor.
Mr Nick is offline
Old January 5th, 2014, 11:27 AM
  #49
bccan's Avatar
Make sure whichever gauge you buy works off WIDEBAND sensor (Heated 6 wire iirc) not a narrow band 3 wire. Wideband is much more precise. Digital readout is the way to go for more precise information. I like the gauges that have both analog & digital readout for feedback like the AEM. That AEM phone app is sweet but I haven't evolved to smart phone yet. Hell, my flip phone is pre camera!
Put bungs in both sides of exhaust & choose which one to use if you care. Be sure to locate where brkts & linkage won't come into play. If running manifolds weld them into pipe just downstream of manifold, otherwise right in header reducer. FWIW I always use the passenger side because there is lotsa clearance. I only install sensor for monitoring & then remove, don't even have to raise car. Remember to anti sieze the sensor threads carefully but I slather it on the threaded plugs, eliminates any fighting on removal or installation.
bccan is online now
Old January 5th, 2014, 02:14 PM
  #50
KDV
KDV's Avatar
Thanks for the help guys!!
KDV is offline
Old April 22nd, 2017, 05:46 PM
  #51
bw1339's Avatar
Any other wideband sensor/gauge recommendations?
Thanks.
bw1339 is offline
Redog
January 14th, 2013 08:07 PM
gtonut57
Aurora
September 27th, 2010 11:15 AM
njot33
August 31st, 2010 04:21 PM
84oldsDelta88
June 24th, 2009 03:40 PM
69SRagtop
May 11th, 2008 11:07 AM
Quick Reply: o2 sensors in older cars
