Cam gear vs distributor gear
Old September 3rd, 2012, 04:36 PM
drjr56's Avatar
Anyone using a Billet roller cam.What type of distributor gear are you using to prevent any damage,and is silicone alloy,bronze my only choice.What is the manufacturer doing when using these cams.I have recently read that composite hardened gears are the ones to use. Thanks for the help.
drjr56 is offline
Old September 9th, 2012, 08:05 PM
Oldmofogo's Avatar
Consult your cam manufacturer, and make sure you are running the proper lube with Zinc additive
Oldmofogo is offline
lyev
June 14th, 2015 04:08 PM
jensenracing77
October 22nd, 2013 04:31 PM
chris83
August 18th, 2012 01:47 PM
sshriber
April 16th, 2010 02:21 AM
scott_442
October 8th, 2008 09:41 AM
Quick Reply: Cam gear vs distributor gear
