Whine/Buzz when turning key (coming from key area) after starter replacement...
Old July 5th, 2011, 05:29 PM
86ChebbyWagon307's Avatar
Hey,
I have an 86 Caprice Classic Wagon (307) and I just replaced the starter, now there is a noise coming from the key or dash area (not the engine) when I turn the key (car DOES start).
Anyway I remember reading something awhile ago about there being a warning system when they key is inserted or turned, if some components in your starter are either too far apart of too close, and that the warning sound was a sort of whine/buzz sound either when you turn the key, or after inserting the key (before turning it). And that when the sound occured would depend on whether the components were either too close or far apart.
In any event, it is happening, and it definetly wasn't there before. My friend thought it sounded like the "key alarm" like when you leave your key in the ignition and leave the door open on some older model cars, but this is not the case because that is a different sound on my car.
Also, sometimes the starter seems to crank it slowly like as if the battery is dieing (battery is fine) or the starter is starting to go, but other times it cranks fine like a new (rebuilt) starter should.
I'm pretty sure there is something going on in the starter that is not supposed to and this low sounding buzz/whine noise is trying to tell me that.
Any insights or suggestions would be helpful, thanks!
86ChebbyWagon307 is offline
Old July 5th, 2011, 06:47 PM
Who did the work?
Was it the correct starter? Are the connections tight and clean? I've never heard of this happening by just replacing a starter. I've changed a few; some were awkward as hell to get at, but as long as you keep it clean and tight it should be fine. If it wasn't doing the noise thing before you had the starter changed, I would suspect the starter.
Allan R is offline
Old July 5th, 2011, 07:09 PM
Wow. I can't imagine what that could be.
Record it with your phone and post the sound file.
MDchanic is offline
BillJack
June 18th, 2015 01:10 PM
1BOSS83
July 18th, 2013 07:58 AM
calioldsboy
September 20th, 2012 01:46 AM
MaxDog
August 29th, 2011 05:13 AM
woodie582
September 19th, 2008 11:14 AM
Quick Reply: Whine/Buzz when turning key (coming from key area) after starter replacement...
