Question about carb numbers in 1967. Some were on discs, some stamped in the body
Old March 30th, 2019, 07:36 PM
2blu442's Avatar
Why do some 1967 carbs have the metal disc with the application number, while others have the numbers stamped like later years? Was this just a transition year so both were used?
2blu442 is offline
Old March 30th, 2019, 09:24 PM
steverw's Avatar
I have two carbs, both im sure originals from 67 442's. It seems i read somewhere the green disc is early, and the stamped number came later.
I may be completely wrong, maybe someone with more knowledge will chime in.
Steve
steverw is offline
Old March 31st, 2019, 06:08 AM
Steve
You are correct. The first couple of years of Qjet production used the disc. By 1968 Rochester transitioned to the number stamped on the carb body. 66-67 carbs with the stamped number are usually service carbs, not OEM.
joe_padavano is online now
Insom
July 20th, 2020 06:19 AM
vickycar
August 1st, 2019 02:08 PM
Octania
April 13th, 2015 09:50 AM
lowkey235
June 18th, 2012 10:40 AM
rodan
November 21st, 2011 09:07 AM
Quick Reply: Question about carb numbers in 1967. Some were on discs, some stamped in the body
