Where to get a new carb from
Old February 11th, 2019, 07:45 AM
NOVICE car nut
oldsguybry's Avatar
I have a 68 Olds Toro 455 in my 72 Cutlass Supreme . Can I get a remanufactured Quadrajet for it or do I need to replace the intake also ? I noticed that Summit has some 750 - 800 CFM carbs but they don't seem to be for this application ... when I type 68 Toro in nothing comes up . Thanks in advance.
oldsguybry is offline
Old February 11th, 2019, 07:49 AM
I suggest you either rebuild the Qjet you have or have it rebuilt professionally. There are members on our site that do Qjet rebuilds. If your heart is set on an aftermarket carb I would caution you against using the Summit carburetor. I have one on my 71 98 and it ALWAYS needs tinkering and I already rebuilt it once. You can get an Edelbrock Thunder AVS or a Holley Street Avenger for a little bit more and they are far superior to the Summit carb,
Olds64 is offline
Old February 11th, 2019, 08:33 AM
Bryan, I found this on the first line of my search. You should be able to determine what you have by looking at the side bowl of the carb and go from there. Is it 4MC or 4MV?
1968 Oldsmobile Toronado Carb Repair Kit
Allan R is offline
Old February 11th, 2019, 11:30 AM
alain's Avatar
Try BFIC carburaters they are in California they are very good.
Alain
alain is offline
Old February 11th, 2019, 11:44 AM
I have used this guy - his name is Rusty Petrovic. He sold me a restored 7042250 for my 72 Cutlass S. It was done to perfection and was very reasonably priced.
The Carburetor Doctor
Allan R is offline
Old February 12th, 2019, 07:51 AM
'72 Cutlass ragtop
70sgeek's Avatar
Ken from Everyday Performance is a Qjet guru - he can customize it to your specs and is very well regarded amongst the Qjet crowd - I have one of his builds on my 350 and it rocks.
http://www.everyday-performance.com/
Another source I've used in the past is Allstate Carburetor - also excellent at general rebuilds and beyond.
https://allcarbs.com/contact/
70sgeek is offline
Old February 12th, 2019, 07:59 AM
Burd's Avatar
Alain
i was was going to say try this place. He may ev3n have the correct number for you.
Burd is offline
Old February 26th, 2019, 02:57 PM
NOVICE car nut
oldsguybry's Avatar
Sorry for late reply , I'm going to do some research and get back here to answer shortly
Old March 13th, 2019, 07:59 AM
NOVICE car nut
oldsguybry's Avatar
IDK , I can't see anymore.... the carburetor had the same issue when I was driving the Toronado. It hesitates / stumbles when you first accelerate the vehicle .
The accelerator pump looks great at a glance, but that is probably the issue
Old March 13th, 2019, 08:14 AM
NOVICE car nut
oldsguybry's Avatar
Maybe this is the issue ?
Old March 13th, 2019, 08:17 AM
NOVICE car nut
oldsguybry's Avatar
I had this carburetor apart and soaked / cleaned everything decent last year , It didn't fix the hesitation . I installed all new gaskets
Old March 13th, 2019, 09:22 AM
delete
droptopron's Avatar
You should see if you have a local guy that knows how to tune a carb. Mine was rebuilt but wasn't ask crisp as i'd like it. I had someone tune it that knows what they are doing & it was a tire shredding monster
droptopron is offline
Old March 13th, 2019, 09:55 AM
Pat
patshotrods's Avatar
oldsguybry,
I just ordered a matching #'s Rochester Q-Jet Carburetor from Guaranteed Carburetors on-line, it will be here tomorrow, it was only $188.00.
Thanks,
patshotrods is offline
Old March 13th, 2019, 10:03 AM
NOVICE car nut
oldsguybry's Avatar
yes , I thought about that also . I messed around with the air gas mixture screws so its probably way out of tune
Old March 18th, 2019, 06:27 AM
NOVICE car nut
oldsguybry's Avatar
Can anyone tell me what brass dishes shown in the picture I posted are ? Would this contribute to the hesitation that I'm getting ?
Old March 18th, 2019, 05:46 PM
rccktmn2's Avatar
If I'm not mistaken they are the well plugs for the fuel well (under where the float sits). These are prone to leaking which caused the fuel to run into the intake which depletes the fuel in the well for the carb to actually use for accelerating and also supplies fuel into the intake when it's not wanted. I can't say that this is your problem but I hope that it helps.
rccktmn2 is offline
Old March 18th, 2019, 06:12 PM
The accelerator pump...is probably the issue
^^x2^^
Vintage Chief is online now
Old March 18th, 2019, 06:14 PM
Originally Posted by rccktmn2
...they are the well plugs for the fuel well (under where the float sits). These are prone to leaking which caused the fuel to run into the intake which depletes the fuel in the well for the carb to actually use for accelerating and also supplies fuel into the intake when it's not wanted. I can't say that this is your problem but I hope that it helps.
^^x2^^
I don't know this as a fact, but I've read the earlier (pre-1970?) had a tendency to leak more so than later Quads.
Old March 18th, 2019, 07:41 PM
Tedd Thompson's Avatar
You don't have to buy anything to check your accelerator pump. Just look down the carb and pump the throttle. There should be a couple of spray nozzles squirting a full stream of fuel. If nothing or broken stream the pump is bad.... Tedd
Tedd Thompson is offline
Old March 18th, 2019, 08:10 PM
72 Olds CS
RetroRanger's Avatar
after rebuild i followed the set-up instructions in the CSM and my qjet lights the tires easily and promptly no matter how hard i stomp the throttle
RetroRanger is offline
Old March 19th, 2019, 07:07 AM
NOVICE car nut
oldsguybry's Avatar
Thanks , I'm going to check the pump first . It has the neoprene seal instead of the leather one . No matter what tinkering I did on this carburetor it still has this hesitation , but only under load . It doesn't do this in park or neutral unless it's cold. IIRC , it was better at one point until I turned the idle up .
Old April 18th, 2019, 05:00 AM
NOVICE car nut
oldsguybry's Avatar
I put a new accelerator pump in but it still hesitates . I'll have to mess around with the carb a bit more and get it tuned properly eventually after a rebuild . Right now I'm more concerned with getting the body primed and sealed so I don't have anymore rust issues .
Old April 18th, 2019, 05:42 AM
BillK's Avatar
What do you have the ignition timing set at ? Try bumping it up a few degrees and see if that helps your hesitation.
BillK is offline
Old April 18th, 2019, 06:16 AM
1968 442 Convertible
bry593's Avatar
Sometimes the check ball gets stuck under the accelerator pump and this will prevent the pump from working. Did you look down the venturis while opening the throttle by hand? You should see a couple of squirts of fuel if working correctly.
bry593 is offline
Old July 16th, 2021, 02:09 PM
David Sloop's Avatar
Originally Posted by patshotrods
oldsguybry,
Thanks,
I know this is a bit of an older thread, but how does this carb work? Are you happy with it?
David Sloop is offline
GoolzCutlass
January 17th, 2018 08:56 AM
wolfman98
August 20th, 2010 05:21 AM
442Cliff
June 9th, 2010 03:04 PM
bullet1
August 23rd, 2009 10:04 PM
ijasond
July 28th, 2009 12:47 PM
Quick Reply: Where to get a new carb from
