Harrison radiator education
Old February 3rd, 2019, 04:41 PM
scrappie's Avatar
What are the codes and tags that are correct for a 1970 442 w-30 4 spd radiator? Is there an embossed code on the tanks along with brass tags that are the correct for that year and model? How do you I.D. the correct radiator?
Thx
scrappie is offline
Old February 3rd, 2019, 06:48 PM
2blu442's Avatar
I believe we need the rear end ratio to say for sure what the radiator code should be. But yes, there's codes stamped into the tanks. I'll post pictures of some examples. On this radiator the big tank is code CA and the small tank is code IA
2blu442 is offline
Old February 3rd, 2019, 06:54 PM
2blu442's Avatar
Often the tags are missing. But here's a couple photos of tags that came on radiators.
2blu442 is offline
Old February 3rd, 2019, 08:06 PM
scrappie's Avatar
Thanks for the info, the car has a 3:91 rear end and I have y eyes on a rad but not sure if correct? It is a 4 spd rad though due to the lack of trans cooling inlets.
scrappie is offline
Old February 3rd, 2019, 08:41 PM
2blu442's Avatar
The reference I'm looking at says you should have a 2.70" thick core heavy duty radiator. The code should be EC, part number 3017101.
2blu442 is offline
Old February 3rd, 2019, 09:46 PM
70Post's Avatar
If it doesn't have the trans cooling inlets then it's NOT the correct style radiator for your car if you're worried about at least having the correct appearance.
70Post is offline
Old February 4th, 2019, 05:28 AM
scrappie's Avatar
OK so the correct radiator would have the trans cooling inlets but just blocked off for 4 spd?
scrappie is offline
Old February 4th, 2019, 06:55 AM
jensenracing77's Avatar
Yes
jensenracing77 is offline
Old February 4th, 2019, 09:30 AM
70Post's Avatar
What Eric said....yes. You can get new plugs for the inlet and outlet if the plugs are missing. ILT sells some.
70Post is offline
Old February 4th, 2019, 10:08 AM
344879M363895
70-442-W30's Avatar
70-442-W30 is offline
Old February 5th, 2019, 07:54 AM
scrappie's Avatar
Here are some pix of what I have. Im thinking maybe another GM a-body perhaps? I would think 4 spd due to lack of trans cooling inlet/outlet? Maybe chevelle, GTO or Buick? Other than appearance (codes/stampings) this seems like an exact fit and would perform the same correct? Anybody know what exactly this would be for?
After some searching Im coming up with 1970 BB chevelle. el camino 4spd HD cooling LS5,6
scrappie is offline
Old February 6th, 2019, 04:42 AM
scrappie's Avatar
Would the IF, CI tanks be correct codes for 1970 W-30 4-spd, 3:91?
I see IF seems to be the embossed code for the smaller tank.
2blu442 are you referring to the tag code or the tank code?
70-442-w30 posted pix of IF and CI with a tag code of EC is that the correct radiator for 70 w-30 4spd 3:91
Thx
scrappie is offline
Old February 6th, 2019, 12:23 PM
344879M363895
70-442-W30's Avatar
Thx
Yes, you got it. This radiator was in my father-in-law's car. Although it was converted to an automatic transmission, this is the correct 3.91 4 speed radiator from what I've been told. Eric can chime in to confirm. I verified somewhere before also, I think from the assembly manual.
Old February 6th, 2019, 02:26 PM
Yes, I am very sure that the EC was the original radiator to that car.
Old February 6th, 2019, 03:02 PM
scrappie's Avatar
Thanks once again gents
scrappie is offline
Old February 7th, 2019, 08:13 AM
344879M363895
70-442-W30's Avatar
Glad to help, scrappie. If you need any other info about the 4 speed W-30, check my gallery. I uploaded hundreds of pictures and tried to document as well as I could. Here is the link: https://classicoldsmobile.com/g/album/4626351
Old February 7th, 2019, 09:02 AM
scrappie's Avatar
Will do.
I talked to Spectra today and they told me they do sell the cores for some radiators but only to radiator shops and that's all the info they gave. I would like to try my hand at re-coring and if I can't do it then off to rad shop. I would think in today's day and age of internet etc... it makes things more obtainable. Ill keep looking around.
One of these days when I get the time and a bit more organized I'll show you guys what I've been working on.
scrappie is offline
Old February 7th, 2019, 09:29 AM
Will do.
Just be careful with radiator shops, lots of bad one out there. Also, most of the new cores come with a strange top and bottom rail. Tell them you want the core ordered with no rails and to use the old ones. If they can't do it then find a new radiator shop. My radiator shop will recore a 4 core radiator with the old rails for around $500. Most of the time it is less. They get the cores made in Michigan somewhere.
Old February 7th, 2019, 02:53 PM
68442's Avatar
Scrappie
Go to Carrolls used auto parts in Lexington Mass. Ask for Johnny they have been doing vintage rad recoring for decades and do them right, he is a vintage car guy. Correct rails etc. I have used them for over 30 years , every radiators was done perfect
Give me a call if you need more info
John
68442 is offline
Old February 7th, 2019, 03:41 PM
scrappie's Avatar
Thanks John, will do
scrappie is offline
Old February 7th, 2019, 05:03 PM
scrappie's Avatar
That looks like a great project and worthy of the concourse restoration. I hope to see the finished product soon.
On another note: that guy who has your original block, just contact him and say, "I know you think the block is worth a lot of money but to be honest its only worth the most to me because of the number stamped on the side and because it blew up in my car, I am willing to give you x amount and if that works fine, if not fine, thanks for your time.
Its really all you can do, don't get caught up in his angling.
scrappie is offline
Old February 8th, 2019, 11:21 AM
I have a number of radiators I am thinking about getting recored and selling here for cost as a service.
Koda is online now
Old February 8th, 2019, 06:18 PM
scrappie's Avatar
Sorry I got you confused with 344870M or something like that, The guy who found his original motor.
scrappie is offline
Old February 9th, 2019, 01:54 PM
344879M363895
70-442-W30's Avatar
Hey, no problem. Lots of people around here so it's easy to do.
Old March 22nd, 2019, 07:58 PM
scrappie's Avatar
Sorry to bring this up again but I need the block off plugs for the auto trans cooling lines. I looked at ILT website and couldn't find anything. Does anyone have a pic of what they look like? or maybe of an original 70 4spd A-body with original Harrison radiator?
scrappie is offline
Old March 22nd, 2019, 10:14 PM
70Post's Avatar
ILT PN is INL10677 64-71 GM Radiator Plugs - $18 pair (includes washers that go under the plugs).
70Post is offline
Old March 23rd, 2019, 05:56 AM
scrappie's Avatar
Thanks Patton. Do you have a different catalogue than their website? I put that part # in and still nothing?
scrappie is offline
Old March 23rd, 2019, 01:04 PM
70Post's Avatar
I have one of their paper catalogs here....it's dated January 2013. I just double checked the PN I posted above and it is correct.
Try searching using "radiator plugs"
70Post is offline
brock1030
April 6th, 2018 06:53 PM
stevengerard
January 29th, 2018 02:11 PM
stevengerard
January 28th, 2018 09:22 AM
jensenracing77
March 14th, 2013 06:12 AM
Mr Shifty Sidney
February 16th, 2013 10:17 PM
Quick Reply: Harrison radiator education
