Body mounts
Someone with a service manual will probably chime in. I would think 7 per side. 1 up at the rad cradle, 1 before the front tire, 1 behind , 1 in front of the rear tire , 1 behind, 1 ahead of the rear bumper and 1 on the top of the hump going over the rear tires. For a total of 14.
Just a guess.
Eric
Just a guess.
Eric
GM was pretty goofy about body mount applications. When I did my '68 El Camino, I found places for additional bolt-in-place mounts that weren't being used--so I shoved extra mounts and hardware in those locations.
My vehicle was a real rust-bucket with some frame damage in addition--but--if I was doing this again, I'd be looking into using the double body mounts at the cowl like the convertibles often do. I think the frame would accept the double mounts, but the body needed some extra sheet metal I'd have to scavenge from a convertible to make it work.
Good luck. That job "can" be a real bitch. Mine was. Other guys breeze through it like nothing.
https://www.chevelles.com/techref/body_bushings.html
Just a guess.
Eric
Just a guess.
Eric
No, they weren't. The body mounts were tuned specifically to meet NVH requirements. Also keep in mind that the frame rail stampings were typically used for multiple body styles, and the additional holes may or may not correspond to what was needed for a different body style.
