mirror fastening
Mirror
For what its worth, 1969 Cutlass is similar to the diagram posted. Special bolts are threaded into bottom of the mirror, then fed into the keyhole slots in door. I think the bolts are reverse threaded.
Thanks for your answer
Correct my car is 1965 98. No that illustration is not showing what i have. Bracket on my car is mounted with 2 screw in door. One earlier owner have cut a bolt and mounted so the mirror only is in place, so it is not steady, and it is not screwed on the bracket . I suppose there must be some sort of halfround bushing, washer and nut where the wires can go clear instead of that cutted bolt ?????????
Thanks for your answers again
As i told i have problem to explain what i mean
The mirror was mounted on car, but the cutted bolt is laying loose in the cromed foot part,, it is something missing for keep it in the right place on that part, the bracket screwed on door is ok
Something must hold footpart and mirror together
The little screw on footpart, hold it to the bracket and the bracket fits on door, but footpart and mirror must hold together with something, thats the 10000 dollars question
I think the problem is that the tab into which the screw that goes in at an angle is broken. I've circled the tab and screw in red the diagram and where it's broken off in yellow in your photo. Without this tab, there is nothing for the mounting screw to screw into, and the mirror will not stay in place. I have the same thing on the rearview mirror on my '67 Delta 88, but mine is not a remote-control mirror.
As you put it, " footpart and mirror must hold together with something." The "something" is that tab, and it's missing.
How i will make this work ?
I cant fint original parts ( i think they was bigger), but i think this will work. Fingerwasher with spring steel. It is trial and error
nitrojunkie1029
Tech Editor's Desk
November 2nd, 2011 01:38 PM
