Help With 1968 OAI W30 Air Cleaner Vacuum Line Routing
Old November 25th, 2018, 03:43 PM
Tjohn8573's Avatar
I’m wondering if someone could share how the vacuum lines should be installed/routed on a 1968 OAI W30 Air Cleaner. Thanks!
Tjohn8573 is offline
Old November 27th, 2018, 06:31 AM
JohnnyBs68S's Avatar
Subscribed.
Its probably shown in the assembly manual. There should be one hose from the manifold to one side of the thermostatic switch, then a hose from the other side of the thermostatic switch to a "T", then each side of the "T" should have a hose going to each of the 2 vacuum motors on the snorkels. There might be a clip on the underside of the air cleaner to hold the hoses going into the thermostatic switch.
JohnnyBs68S is offline
Old November 27th, 2018, 08:01 AM
Originally Posted by JohnnyBs68S
Subscribed.
It's shown in the Chassis Service Manual also.
joe_padavano is offline
Old November 27th, 2018, 08:28 AM
Tjohn8573's Avatar
Thanks for the reply’s. i have not been able to find the information in the assembly manual. Maybe my old printed version is missing a page. I can can find where the air cleaner and such are shown but there is no detail on how the vacuum hoses should be properly routed. I assumed maybe a tee or something but wasn’t sure. Does anyone have a picture maybe. Thanks Tim.
Old November 28th, 2018, 02:18 PM
So a theory of operation question, these were vacuum motors that would pull the doors shut under vacuum and spring open with no vacuum and they had vacuum when the engine was not warm enough to shut off the vacuum at the choke's thermostatic switch. Idea is to have OAI when engine is warm, and exhaust chimney air when not. I assume, if you buried it while cold, you'd temporarily lose vacuum and get OAI that way.
Now the 70-72 OAI had a flapper that was purely off engine vacuum from manifold, and you'd get OAI at low vacuum, ie, burying it, regardless of engine temp.
Are both of those correct theory?
Koda is offline
Tjohn8573
April 8th, 2019 12:22 PM
hueveaj
October 29th, 2013 12:53 PM
mmbuffny
August 9th, 2013 02:23 PM
droptopcad
October 24th, 2010 04:44 PM
442oldslawyer
May 16th, 2010 07:15 PM
Quick Reply: Help With 1968 OAI W30 Air Cleaner Vacuum Line Routing
