Converting Carb to Electric Choke
Old November 20th, 2018, 07:17 AM
BrawnyMan's Avatar
Hello All,
I recently picked up an intake manifold and a 4-barrel carb (Quadrajet 7043250) along with the cables and brackets from a 1972 Cutlass Supreme and intend to install it on my 1971 Cutlass Supreme that has a factory 2-barrel carb. The carb that I bought is used but I found a rebuild kit off Carb Unlimited and the designations are in the following link:
http://www.carburetion.com/CarbNumbe...Number=7043250
My question is, can I use this Electric Choke Conversion from Carb Unlimited to convert the carb that I am intending on rebuilding to an electric choke? Is it worth it?
Conversion part in question:
http://www.carburetion.com/Products/...spx?Part=CU445
Any tips and tricks for converting from a 2-barrel to a 4-barrel are appreciated as well!!
Thank you,
BrawnyMan
BrawnyMan is offline
Old November 20th, 2018, 08:12 AM
The rebuild kit you linked shows the carburetor with an attached hot air choke. The electric choke conversion you linked is for a divorced choke. Does your Qjet have a divorced choke?
Olds64 is offline
Old November 20th, 2018, 08:16 AM
Your carb is actually from a 1973 350 Olds (7043250 is a 1973 carb number). It should have an integral hot air choke. That kit you linked is for a carb with a divorced choke and won't work. More to the point, you don't need a "kit", you simply need to replace the hot air choke coil with an electric one. I typically use Standard Motor Products P/N CV329, available from RockAuto. They also sell the special electrical connector. You can wire it as shown in this thread.
joe_padavano is offline
Old November 20th, 2018, 08:34 AM
BrawnyMan's Avatar
I am not sure to tell the difference to be honest. I can post some pictures later this evening. For now, I do have some pictures of the the number and the plastic plate on the choke.
Old November 20th, 2018, 08:41 AM
JoeP was right on the money. Do what he mentioned.
Once you convert to an electric choke, get a brass cap from the hardware store to plug the choke housing where it connects to the choke stove.
Olds64 is offline
Old November 20th, 2018, 08:43 AM
It's a 1973 Olds carb. All 1973 Olds Qjets used an integral choke.
Old November 20th, 2018, 08:45 AM
I can't decode Qjet numbers just by looking at them. My mind is filled with too much useless information... like how to brew beer.
Olds64 is offline
Old November 20th, 2018, 08:55 AM
Actually, the third digit is the decade - 4 = 1970s, 2 = 1960s. The fourth digit is the year. 7043xxx = 1973 model year. Olds carbs typically (but not always) are in the 250s for the final three digits.
Old November 20th, 2018, 10:06 AM
BrawnyMan's Avatar
So the following rebuild kit ( http://www.carburetion.com/products/...?part=KT-5195C ) will not work for the carb I have?
Thank you for all the great info.
Old November 20th, 2018, 10:24 AM
The description says it will work on your 1973 QJet.
  • Applications: Quadrajet - CAD 70-74 OLDS 67-75
I looked the kit up by your carb number and the kit number you linked above is correct.
Fun71 is offline
Old November 20th, 2018, 11:57 AM
72Cutlass S
gs72's Avatar
Joe must have a really thick skull to keep his head from exploding from all of the knowledge that is crammed in there.
gs72 is offline
Old November 20th, 2018, 12:32 PM
friesjh's Avatar
Actually q-jets from 1965-1969 show 702 as the first three digits, 1965-1969 California and altitude applications show 703 as the first three digits, 1970-1975 show 704 as the first three digits and 1976-1979 carbs show 1705 as the first 4 digits. The fourth digit is the application year. The fifth digit is the original application is federal or California. The 6th digit is the GM division and the last digit shows transmission usage with even numbers being automatic, but is not always true. So the q-jet number 7043250 is 1973, federal application, Oldsmobile, and could be an automatic transmission. The last digit may or may not be. For instance the correct q-jet for my 71 automatic 442 is 7041257 and for my 71 4 speed its 7041256, so check you service manual to be sure of the transmission type.
friesjh is offline
Old November 20th, 2018, 12:48 PM
shiftbyear's Avatar
2 things to remember when doing the conversion, the new choke unit grounds through the carb so remove the paper gasket from the old choke unit, second wire the pigtail to a 12 voltage source with the key in the "ON" position. Otherwise it will have power all the time and drain your battery. Good luck.
shiftbyear is offline
Old November 20th, 2018, 02:46 PM
Your info may apply to Chevy carbs, but not to Oldsmobile carbs. The actual details vary by year, but here's a sample of 1968-70 Oldsmobile carb numbers. This comes from the Oldsmobile Dealer Service Guild bulletins. Odd and even are unrelated to manual vs. automatic. 703xxxx was never used by Oldsmobile. The third digit was always either a "2" for the 1960s or a "4" for the first half of the 1970s. The fifth digit is NOT Calif vs. Federal. Actually, why would Rochester need to indicate Calif vs Fed in BOTH the third and fifth positions?
Here is yet another example. For the 1967 model year, BBOs used the 7027156 Qjet on RWD cars without A.I.R. (ie, on 49-state cars) and the 7027157 Qjet on Calif cars with A.I.R. That pretty much violates every single one of your "rules", since the Calif carb has a "2" in the third position, the same "1" in the fifth position as the 49-state carbs, and the last digit odd/even has no relationship to the trans.
Old November 20th, 2018, 02:48 PM
Wire it through an oil pressure switch as described in the link I provided in my first post in this thread. That way the choke won't heat up if the key is in the RUN position but the engine isn't running.
Old November 20th, 2018, 03:03 PM
Well, apparently every source on the web, including Cliff Ruggles, has repeated that bogus info on Qjet carb numbers. Suffice to say that they are all wrong. Here's my "bible" on the subject:
Old November 20th, 2018, 03:44 PM
friesjh's Avatar
I stand corrected. I have been reading Cliff's q-jet book and that's where the info came from. From the 70 and 71 carbs I've seen it has held true.
friesjh is offline
friesjh's Avatar
By the way, that is an impressive book!
friesjh is offline
Old November 20th, 2018, 03:52 PM
I'm not sure what 1970-71 Oldsmobile carbs you've seen, but just about all of them violate the "rules" on numbering:
7040250 was used on 350s with both AT and MT
7040251 was used on 455s with AT
7040255 was used on W-31s with both AT and MT
7040256 was used on W-30s with MT
7040257 was used on 442s and W-33 with AT
7041250 was used on 350s with both AT and MT
7041251 was used on 455s with both AT and MT
Old November 20th, 2018, 04:06 PM
friesjh's Avatar
Joe - I am really sorry if I somehow offended you, but that is pretty much what I wrote, "The last digit may or may not be. For instance the correct q-jet for my 71 automatic 442 is 7041257 and for my 71 4 speed its 7041256, so check you service manual to be sure of the transmission type.".
friesjh is offline
Old November 20th, 2018, 04:56 PM
No offense taken. My point was that the most common carbs used by Olds in most years are the '250 and '251, and the last digit has nothing to do with the trans. The third digit has nothing to do with Calif vs 49 state and the fifth digit has nothing to do with that either. That wasn't directed at you, but at the bad info that has been repeated on the web. If folks who should know better (like Ruggles) would actually check this stuff out before posting it, the community as a whole would be better informed.
Now don't get me started on nickel content...
Old November 22nd, 2018, 04:10 PM
Oldsdruid
rocketraider's Avatar
Just rewired my Cruiser wagon's electric choke per Joe's instructions. Works like a dream. You can see this thread for what I went thru before, when Holley ProShops put a 2-barrel choke coi on my rebuild. https://classicoldsmobile.com/forums...-choke-bs.html .
rocketraider is offline
BrawnyMan
March 28th, 2019 06:59 AM
allyolds68
September 20th, 2017 05:00 PM
Pfiffle
December 20th, 2016 01:52 PM
455man
June 15th, 2012 06:33 PM
HouTXCutlass
October 4th, 2010 11:54 AM
Quick Reply: Converting Carb to Electric Choke
