Speedometer Calibration
Old November 16th, 2018, 10:47 AM
Rocketbrian's Avatar
I notice when driving my 3 71s, the speedometers read approximately 5 -7 miles faster than actual GPS readings, depending on road speeds. On my 71 SX hardtop and 71 442 I have 225/70-14 tires and on my 71 SX convertible, 235/60-15s, both smaller in diameter than the G70-14s they came with. I understand from reading the searched results the speedometers may have been a bit optimistic contributing to part of the discrepancy noted.
All have 18 tooth drive gears in the TH400s. The convertible has 2:56 gears with a 35 driven gear, the SX hardtop 3:08s with a 43 tooth gear and finally the 442 has 3:23s and a 45 tooth driven gear. Now for my question, approx. how many mph change would there be for each increase in tooth count of the driven gear with the tires I have? I can increase the SXs tooth count, but the 442 already has the highest tooth count before going to an adapter, which I wouldn't bother doing.
I'm thinking of ordering new driven gears but didn't know whether to go up 1 or 2 in tooth count. Any mathematicians out there?
Rocketbrian is offline
Old November 16th, 2018, 02:31 PM
Gary
VC455's Avatar
Brian, you've done all the hard work already.
It's easy to figure the driven gear from your data. Take the displayed speed, divide by the GPS speed, and multiply by the number of driven teeth; this equals how many teeth you need to correct the mismatch.
For example, if your speedo shows 65 mph, your GPS shows 60 mph, and you have a 35 driven gear... 65/60 x 35 = 38 teeth.
VC455 is online now
Old November 16th, 2018, 02:55 PM
There is a speedo gear chart on TCI frequently ask questionS forum. You need to know the exact tire diameter, and one of the gear tooth count, and it will calculate the other gear needed. Depending on which driven gear is needed, you may also need to change the speedo gear housing.
matt69olds is online now
Old November 16th, 2018, 04:10 PM
Thanks for the info, I'll do the calculations.
Docs72
October 8th, 2019 08:02 PM
Minnesotajeff
February 4th, 2019 08:58 AM
4SPEED67
February 21st, 2018 05:41 PM
W-27
Drivetrain/Differentials
August 13th, 2013 01:05 PM
Beltman
15
October 14th, 2010 04:10 PM
Quick Reply: Speedometer Calibration
