Vent window rubber replacement?
Old October 14th, 2018, 05:16 PM
Platinum69's Avatar
Any tips or videos on how to replace the rubber seal around the door vent window?
Platinum69 is offline
Old October 15th, 2018, 05:19 AM
Oldsmaniac's Avatar
YouTube has video's of this on a Chevelle I think. You need to remove pop rivets and then re rivet when done. The frame needs separation to install rubber.
Oldsmaniac is offline
Old October 15th, 2018, 12:22 PM
Oldsmaniac's Avatar
Do not remove rivet that hinges the glass. Pick the 2 that hold the frame together.
olds3031
October 9th, 2016 09:34 AM
tcarroll
December 16th, 2012 11:56 AM
jread199
October 16th, 2012 07:45 AM
billykissell
February 25th, 2011 06:22 AM
cbogartjr
August 13th, 2010 12:34 PM
Quick Reply: Vent window rubber replacement?
