70 Disc Brake Metering Valve Stuck - Is It Bad Or Can It be Fixed?
Old August 21st, 2018, 06:21 PM
costpenn's Avatar
I was cleaning this valve up for a resto I'm doing. After cleaning the rubber cup and wirewheeling the body, I notice the valve seems to be stuck. I can't move the metal stem in any direction - should it be very hard to move or is it stuck? Can it be serviced or should it just be replaced?
costpenn is offline
Old August 21st, 2018, 06:37 PM
The seals are just o-rings. If you can get it apart, you should be able to hone the bore and replace the o-rings. You will likely need to match up the old o-rings with new ones from a source like McMaster Carr.
joe_padavano is online now
Old August 22nd, 2018, 06:14 AM
oldspackrat's Avatar
I have 1 or 2 if it can't be rebuilt.
oldspackrat is offline
Old August 22nd, 2018, 07:19 AM
Lance
ROCKET VAPOR's Avatar
Replacement parts
https://www.musclecarresearch.com/gm...ing-seal-kit-2
Instructions
https://www.musclecarresearch.com/gm-1233464-rebuild
ROCKET VAPOR is online now
Old August 22nd, 2018, 08:11 AM
costpenn's Avatar
Thanks to all - ordered the rebuild kit and got the diassembly instructions.
costpenn is offline
1k442
Brakes/Hydraulic Systems
July 3rd, 2017 10:05 AM
jensenracing77
May 28th, 2013 02:15 PM
Mark71
March 26th, 2013 06:05 PM
mmurphy77
May 2nd, 2011 08:09 PM
buds68a77
February 5th, 2009 04:15 PM
Quick Reply: 70 Disc Brake Metering Valve Stuck - Is It Bad Or Can It be Fixed?
