'70 Sport mirror part #
Hi Guys, Looking at getting a set of used sport mirrors. Seller has part numbers, but want to make sure they match...anyone have the part #'s off their sport mirrors for comparison? Thanks!
Here's info from what is on mirrors from seller:
Driver side: JC60383-401 06496
Passenger: JC60384-401 404494
-Ryan
-Ryan
Group 10.185 RH 406495 f85 - 2 Drs with sport mirror, (sport manual paint to match )
Group 10.185 LH 406494 f85 - 2 Drs/ with sport mirrors (LH remote control outside less escutcheon - paint to match)
If you get pics, the 70 mirrors are distinctive & one year only. The later ones are "egg shaped" where the 70 has a noticeable crease in them. There is also no visible mounting screws on the 70 mirror as they have two bolts that go through the door skin. The later ones have a mounting screw in the base that goes to a bracket that mounts on the door.
by https://www.flickr.com/photos/158535685@N07/, on Flickr
They need to be from the front.
Also be careful - These 70 (one off) mirrors are reproduced. The numbers you originally quoted don't come close to GM parts numbers. Ask if they are reproductions.
I believe the seller is trying to show you the difference between the 71/72 mirror and the 70
IF the mirrors are these ones in the picture, they appear to be the right shape for 70 mirrors. Ask if the RH mirror comes with mounting hardware.
From what I can see in the pictures, it's just what Ron said about mounting. You'll have to remove the door panel to attach the RH mirror. There is a stiffener sold by InlineTube to reinforce the RS door where the mirror attaches and seems to mimic the LS door reinforcing. Looks like this:
70-72 Sport mirror attachment bracket
Mirror
Thanks! Nice part is interior is totally out so I’m in good shape.e
Support
^^^As noted, you likely will only need the passenger side to be reinforced. Check your drivers door skin. It should be fitted with this for the existing mirror. If it isn't, get a support for it too.
Ron, I don't think he had remote mirror on the drivers side, but I believe all the drivers doors were reinforced for the mirrors back then. Comments?
My car originally had the D33 remote mirrors on them from factory, but was supposed to have D35 Sport Mirrors(crossed out and hand written as D33) will I need to change anything else to put sport mirrors on? I will get the passenger side for sure now and check to see bracket on current driver side.
