remove a grease fitting from lower ball joint
Hi Everyone Question: Can anyone tell me how to remove a grease fitting from the lower ball joint? I tried an easy out but the fitting keeps turning I don't want to replace the ball joint if I don't have to. I have no Idea how the end was broke off. Any help would be greatly appreciated and keep on cruising.
Some replacement grease fittings were " pound in "and not threaded. My bet is someone installed one of these somewhere along the road. I would take a pair of vice grips and get a good grip and try to pull or pry it out.
If the easy out keeps turning the fitting at least it has a grip? Can you get something on the end of the easy out and tug on and pull it out? What year of car? I never heard of a pressed fitting zerk fitting-must be a pre-64 sweetie at least??
Alemite® Drive Fittings
Used extensively to avoid tapping costs in a wide variety of applications
Alemite serrated shank grips securely and simplifies the replacement of damaged fittings in old or oversized holes
Recommended only for low and medium pressures
defiant1
March 16th, 2015 09:44 AM
RATCHETMASTER
Brakes/Hydraulic Systems
October 20th, 2011 07:32 PM
