Lights
Old July 19th, 2018, 05:09 PM
Yenko_66's Avatar
Lights
Im haveing a problem with the reverse lights have power switch good bulbs is good but wont light up when i hook the lights up the sockets have power and the bumper gains power so im kinda lost with the test light lights up when i touch the bumper when i have the lights hooked up HELP
Yenko_66 is offline
Old July 19th, 2018, 06:14 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Sounds like the lights are not grounded to the bumper.
redoldsman is offline
Old July 19th, 2018, 06:32 PM
The test light is getting its ground off the bumper. Check what Glenn said - trace back the ground wire from the loom and check it. Chances are there's corrosion that's causing the problem. Remove the ground, clean it and the mating surfaces. Reattach and test for operation. If it's good, cover the ground with something like copper coat or any good rust inhibitor.
Allan R is offline
Old July 19th, 2018, 06:49 PM
If your getting 12v on the bumper, the bumper is not grounded to the frame.
oldcutlass is offline
Old July 19th, 2018, 07:11 PM
redoldsman's Avatar
Eric, I don't understand your comment. The way I read it is that if he touched a test light to the bumper, it lite up. Maybe I am not understanding it correctly. It is going to be close to impossible for the bumper not to be grounded to the frame.
Old July 19th, 2018, 08:08 PM
Yenko_66's Avatar
Lights
Thank you all for the help im not sure if i stated its a 65 cutlass .
all the wires are good the light buckets are the ground and all cleaned with good contact iv tried what i think is everything just at a loss at this time
thanks again
Yenko_66 is offline
Old July 20th, 2018, 04:48 AM
Which, the b'up light or the probe?
Phoenix8990
September 4th, 2019 07:18 PM
brandon reynolds
March 20th, 2018 05:26 AM
my72olds
June 30th, 2014 11:47 AM
jeffreyalman
April 14th, 2010 08:46 PM
projectheaven
January 5th, 2008 07:01 PM
Quick Reply: Lights
