55 Olds oil filter base.
Old June 28th, 2018, 05:15 PM
ponder48's Avatar
I'm cleaning up the engine in my 55 Olds preparing it for a rebuild. I took the oil filter base off to disassemble and clean. While unscrewing the cap over the ball and spring (I'm hoping that's an anti-drain back valve) the spring got all twisted up because of the sludge inside the housing. Now I can't seem to get it untwisted. Google hasn't helped me find a new spring. Does anybody have a clue where one might be found? Also, is the ball valve just a pressure relief valve, or is it an anti-drain valve?
ponder48 is offline
Old June 28th, 2018, 07:52 PM
Tedd Thompson's Avatar
If you can't find a spring a alternative is to use a spin off adapter which can be found/ bought From Ross Racing, Fusick , E bay or off any 394 or late 371. It's a bolt on easy fix.... Tedd
Tedd Thompson is online now
Old June 30th, 2018, 05:18 AM
ponder48's Avatar
Thanks!! I've found a few bases on ebay, etc. and will get one of them if I can't unravel my spring. Got most of the kinks out yesterday, but had to stop when my eyes got crossed from trying to follow the loops! Doncha just love a challenge?
ponder48 is offline
Old June 30th, 2018, 06:59 AM
I do most of my fine work with with mu eyes closed, ain't old age a challenge .... Tedd
Old July 1st, 2018, 04:52 PM
ponder48's Avatar
Well, the best price I've found is $50 plus $15 shipping. That's a lot to pay just to get a spring. It sure would be great if there were some sort of info on this part on the internet, but so far I haven't found anything. Do you know if this is a pressure relief valve, or an anti drain back valve? I've noticed some main knock if the engine started before the pump built up pressure.
ponder48 is offline
Old July 1st, 2018, 05:27 PM
2blu442's Avatar
I might have the part and can let you have it for much less than that. This is the piece that bolts onto the block, that the canister filter fits into, correct?
John
2blu442 is online now
Old July 1st, 2018, 05:47 PM
2blu442's Avatar
Sorry, I'm not real familiar with your vintage of Olds. But is the spring you need inside this piece? If so, I'd take $15 plus shipping for it. Or... do you want me to take the big plug next to the brass fitting off and see if the spring is good (if that's where its at?) and if so just ship you the spring? John
P.S. I've dismantled a 303 and 324 in the past and am pretty sure this came off of one of those engines.
Old July 3rd, 2018, 12:43 PM
ponder48's Avatar
Yes 2blu442 that is the piece. I'll take it!! Just let me know how to get the $$ to you and it'll be on its way. I'll be out of town Tue afternoon and Wed, but will be back on Thur. Will check my messages then and get it coming. Thanks LOADS!!
ponder48 is offline
Old July 3rd, 2018, 12:44 PM
ponder48's Avatar
I forgot to mention, don't try to dismantle it. I'll soak it in WD-49 to loosen up the crud inside. The crud is what ruined my spring.
ponder48 is offline
Old July 3rd, 2018, 02:45 PM
2blu442's Avatar
Glad to help out! I'll get it packaged up, I'll need your shipping address for the shipping costs. I'll send you both an email and PM with my contact information. John
Old July 10th, 2018, 01:58 PM
ponder48's Avatar
Hey folks, got my filter base yesterday and it's just what I needed. Dismantled it without the spring twisting up and now I'm ready to put it all back together. Now THIS is the way folks help other folks!
ponder48 is offline
Old July 10th, 2018, 02:00 PM
Proud Viet Nam Veteran
redoldsman's Avatar
John is one of the best guys on here and always helps other out. It is guys like him that make the hobby fun. He is not an opportunist.
redoldsman is online now
Old July 10th, 2018, 02:54 PM
X2 on John.... Tedd
GTC
35
July 29th, 2021 05:17 PM
theold52
December 17th, 2017 08:50 AM
kirkwoodken
March 31st, 2017 01:34 PM
TripDeuces
May 4th, 2014 05:48 PM
mike623
October 18th, 2010 09:07 AM
Quick Reply: 55 Olds oil filter base.
