70-72 Cutlass Trunk Lids ?
Old May 29th, 2018, 02:18 PM
shockrebuild's Avatar
How many different trunk lids are made for 70-72 Cutlass? I see postings for convertible or Supreme but aren't the convertibles rounded on top side and Supreme has sharp corner? The we also have the Cutlass Fastback style also correct? So I count three. Are some people just confused about Supreme/ Convertible. Has anyone ever rounded off a Supremes to use on a convertible?
shockrebuild is offline
Old May 29th, 2018, 04:12 PM
71 cutlass convertible
lshlsh2's Avatar
4door/convertible
supreme
"S"
lshlsh2 is offline
Old May 29th, 2018, 04:18 PM
Yep, a fella in the local Olds club did this many years ago for his 71 Supreme convertible. He said welding and finishing the edge was quite a job.
Fun71 is offline
Old May 29th, 2018, 04:28 PM
Originally Posted by lshlsh2
4door/convertible
supreme
"S"
Well, to be technically correct:
Town Sedan, Holiday Sedan, and Convertible (xx39, xx69, and xx67 body codes)
Supreme Holiday Coupe (xx57 body code)
Sport Coupe and Holiday Coupe (xx77 and xx87 body codes)
Keep in mind that the Supreme could have come as a four door, convertible, or notchback coupe. Not all Supremes used the same trunk lid.
joe_padavano is offline
Old May 29th, 2018, 05:53 PM
ragtopblue's Avatar
The Vert is definitely rounded ! And that would be the same for all Supremes, 442's and SX's since they are all the same body for the convertible 70/72. Not to be redundant !
ragtopblue is offline
Old May 30th, 2018, 08:07 AM
Also, to be yet more technically precise, the part numbers are many more than that due to emblems. The 4 door, Cutlass Supreme convert, and 442 Convert used the same lid, but with different trim holes.
Koda is offline
Old May 30th, 2018, 08:20 AM
Well, yes and no. The replacement lids came without holes drilled, so there were only three P/Ns:
9877968 - 4257 body (Supreme notchback)
9852222 - More doors and Convertibles
9852218 - all 2drs except 4257 or convert.
Now, on the assembly line, these were drilled in the different patterns, presumably using "make from" drawings, and as such would each have unique P/Ns.
Old May 30th, 2018, 08:51 AM
Good point, but I would think they were pierced in stamping.
Koda is offline
Old May 30th, 2018, 09:42 AM
Interesting, I have I guess a Supreme lid then with aftermarket wing . The lid was NOS in 80s and painted poorly yellow , then car was wrecked a short time later the last owner said. Am going to sell trunk lid so was wondering if any body guys have ever rounded off corners to make it fit a Convertible if someone needed ?
Thanks for all the great info guys
Old May 30th, 2018, 09:45 AM
I wonder what spoiler it has on it? I don't think the 72 H/O even had a spoiler.
Koda is offline
Old May 30th, 2018, 12:05 PM
You're correct. None of the 72 Cutlass offerings included the deck wing as an RPO It was cancelled 3/31/71
Allan R is offline
Old May 31st, 2018, 05:03 AM
Not sure on spoiler thou I know the owner said he purchased it at the same time of trunk lid?
Old May 31st, 2018, 05:09 AM
Some pics
Bad prep job for paint
Old May 31st, 2018, 10:09 PM
Gary M's Avatar
Are there three bolts on each side holding the wing on or two on each side? I think the repops used two.
Gary M is offline
rhaberm
February 13th, 2018 12:38 PM
olds3442
March 19th, 2013 01:32 PM
tmatador
October 27th, 2011 03:20 PM
nelsontj
Body work
March 8th, 2009 05:03 PM
h-bomb
December 9th, 2007 06:32 AM
Quick Reply: 70-72 Cutlass Trunk Lids ?
