68 Cutlass Carb Choke Thermostat - 2V
Old May 18th, 2018, 07:27 AM
jmt147's Avatar
I have a 1968 Cutlass 350 2V. I need to replace the Carb Choke Thermostat. Is this the correct one? as it only list the 4V? Standard Motor Products CV136. Picture of current part is attached. Thanks! https://www.summitracing.com/parts/s...iABEgISovD_BwE
jmt147 is offline
Old May 18th, 2018, 09:27 AM
JohnnyBs68S's Avatar
I can't imagine why they'd use a different thermostat spring on a 2V vs a 4V. The part on SMP's and Summit's sites looks like it'll work. Might be a $16 gamble.
You might also post in the parts wanted section, I imagine there are a bunch of 2V carbs that have been pulled off when converting to a 4V intake / carb that are laying around.
JohnnyBs68S is offline
Old May 18th, 2018, 12:07 PM
I'll tell you why. The choke thermostat spring on the 2GC carbs is coiled in the opposite direction from the one on the Qjets - at least until the mid-70s when the 2GC choke linkage was changed. Be careful, some vendors show the later choke coils as working on the early 2GC carbs. They do not.
joe_padavano is offline
Old May 18th, 2018, 12:09 PM
We actually had a similar discussion about this a couple of months ago in this thread.
Old May 18th, 2018, 02:58 PM
lemoldsnut's Avatar
I have a 68 350 2 barrel be happy to sell you the entire carb for $25 plus shipping.
Larry
lemoldsnut@aol.com
or calls 541-815-4363
lemoldsnut is offline
Old May 18th, 2018, 06:50 PM
jmt147's Avatar
Thanks all for the education.
Larry - sent you an email.
Jeff
jmt147 is offline
240 Gordy
October 11th, 2020 10:04 AM
442mark
September 22nd, 2013 05:50 PM
66olds4dr
May 31st, 2013 05:47 PM
1k442
November 27th, 2012 11:18 AM
ros6872
August 28th, 2012 09:32 AM
Quick Reply: 68 Cutlass Carb Choke Thermostat - 2V
