Brake booster
Frankly, the manual disc brakes that came stock in my 70 W-30 work fine. If you MUST have power, use a hydroboost.
If you are doing this because you want to clear tall valve covers, don't. A 7" booster is next to worthless. There are only two things that control the amount of boost from a power brake booster - air pressure and booster diameter. Unless you are driving up Pikes's Peak, air pressure is pretty much the same. That means that the booster diaphragm diameter directly governs boost. Stock booster is an 11" - that's about 95 sq in of diaphragm area. A 7" booster has about 38 sq in of diaphragm area, so you'll only get about 40% of the assist as you would with stock. Even a dual diaphragm 7" booster only gives you about 80% of stock. Don't waste your time.
zodiacblueS
Brakes/Hydraulic Systems
44
October 12th, 2014 03:22 PM
plasma98
April 20th, 2007 12:06 PM
