Holley 6212 AAA 800 cfm Spreadbore
Old April 15th, 2018, 06:16 PM
SY2455's Avatar
I was thinking about shopping for 1 to try out. I know that they are no longer making it so I would be looking for NOS or used. Has anyone used it before? So that I may learn from your experience before going down this route.
Thank You ahead of time.
SY2455 is offline
Old April 16th, 2018, 07:18 AM
I ran one of these spreadbore Holley carbs years ago. Don't waste your time. Get a properly built and set up Qjet. Your car will thank you.
joe_padavano is offline
Old April 16th, 2018, 08:17 AM
My old man had a spreadbore Holley on his 71 Corvette with stock 350.
It did a couple things differently.
The Holley would not let fuel evaporate so much, and the QJ required more cranking when sitting for a while.
The QJet did not load up while idling which the Holley did.
The Holley had mechanical secondaries and you would feel the boot of the gods when they kicked in; the Qjet was more smooth.
The Holley would let the car do 135 all out, and the QJet allowed 125, circa when new, 1972.
Koda is offline
Old April 16th, 2018, 08:25 AM
HX3
HX3's Avatar
Not mine.
https://www.ebay.com/itm/HOLLEY-800-...havsfu&vxp=mtr
HX3 is offline
Old April 16th, 2018, 10:19 AM
So does the Qjet. Adjusting the spring wrap on the air valve and dialing in the orifice on the dashpot will give you the same feeling.
Old April 16th, 2018, 10:46 AM
I wasn't precise enough. The Holley did not have the vacuum air horn valves the QJet has. Mechanical secondaries, in my terms, means the whole back two barrels, not just the throttle blades.
Koda is offline
Old April 16th, 2018, 10:50 AM
The Qjet has mechanically operated secondary throttle plates, period. The air valves obviously open in response to mass air flow through the secondaries, but they can be adjusted to preclude any added resistance. If properly adjusted, this will not be a performance loss.
Old April 16th, 2018, 11:22 AM
What are you going to use it on? What manifold?
oldcutlass is offline
Old April 17th, 2018, 05:55 AM
SY2455's Avatar
I was thinking of using it on our W-30 so that I wouldn't have to alter the factory carb. Our car currently has the Sig Erson Hy Flow2 cam in it with the stock intake. Not really wanting to change the intake. I have use the Holley 650cfm Spreadbore in the past and really like it. That is why I was thinking of the 800cfm on the stock intake.
SY2455 is offline
Old April 17th, 2018, 06:04 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
That one on eBay looks good. If you are familiar with them, grab that one. The factory W-30 carb is only 750 cfm, mods like adjusting the air door to open more might help.
olds 307 and 403 is offline
Old April 17th, 2018, 06:26 AM
Its hard to compete against a quadrajet and I don't think you'll gain anything. With that said the Holley 6212 is a good carb compared to its 6210 counterpart.
Old April 17th, 2018, 12:40 PM
I don't know how it did it, but the Holley made the engine jump harder.
Koda is offline
Old April 17th, 2018, 03:52 PM
2olds's Avatar
I try one on my car never took it off run better then any Qjet and easy to tune.
2olds is offline
Old April 17th, 2018, 03:53 PM
SmirchIs#1's Avatar
I agree with Old Cutlass,if prepared by someone who understands Q-jets and knows their faults,they are an awesome and trouble free carb.However the Holley spread bore is also an awesome carb,I have built many with never a problem.I have three in service in my own vehicles right now.When building a Holley you must be surgically clean as they will tolerate ZERO foreign material.If you choose to go that route,I have several of them if interested
SmirchIs#1 is offline
Old April 18th, 2018, 04:34 PM
SY2455's Avatar
While that Carb on Ebay looks temping, I don't like working with Ebay and do not have the means to do so.
When you say several, what kind of shape and condition are we talking about? PM me if you would like to keep personal information safe.
SY2455 is offline
Old April 19th, 2018, 03:01 AM
shiftbyear's Avatar
A major thing to consider is that Quadrajets were federal emission carburetors so they had precise idle and cruise fuel metering. Off the shelf Holleys could dump as much gas as they wanted and worked better on modified engines. Quadrajet idle/cruise circuits can me modified for high performance engines and give great throttle response. Check out this video as proof.
shiftbyear is online now
Old April 19th, 2018, 06:37 PM
dragline's Avatar
https://www.youtube.com/watch?v=nyyRoaeujiA
Wow, must've watched that video at least 5 times. Thanks for posting
dragline is offline
Old April 20th, 2018, 05:43 AM
SmirchIs#1's Avatar
Holley spreadbore
I looked & don't have a 6212.I do have 6211's & 6213's,both are 800 cfm and have divorced choke.I also have a 6910 which has manual choke & is 800 cfm.$175 plus ship.If stiil interested I'll send you pics of what you choose.I will disassemble to check for any issues.oxidation or incorrect parts.I will quarantee you a good rebuildable core carb.If you're not in a hurry I could build it for you,but right now I'm swamped doing rears and muncies.Dennis
Old May 1st, 2018, 02:41 PM
SY2455's Avatar
I'm not in a hurry as our car is still in Calif. How much would it be for you to setup the 6213 for me?
SY2455 is offline
rcktdoc
September 29th, 2017 04:34 AM
70sx455
August 20th, 2015 04:27 PM
70sx455
June 30th, 2015 10:29 AM
70sx455
February 14th, 2014 12:49 PM
Quick Reply: Holley 6212 AAA 800 cfm Spreadbore
