1970 Cutlass heater control valve with A/C
I’ve seen many versions of heater control valves on ‘68-‘72 A bodies.. Can someone tell me which would be factory issue correct on a ‘70 Cutlass with air conditioning? These pictured are the two that I’ve most seen. Thank you
I know on the 69 and 70 heater valve, they are the small threaded port as shown above.
Also, if you can blow through it, it will be the right one. 69-70 need vacuum
to keep the valve closed. And the 71 up uses the larger threaded port and needs vacuum
to open the valve. At least that is how it was explained to me.
Sorry bud, I got that a little backward. If you can't blow through it, it will be the right one.
The 69-70 need vacuum to open the valve. Here's a pic of an aftermarket unit I purchased
for my 70 w/455.
for my 70 w/455.
jensenracing77
March 19th, 2014 04:08 PM
