1955 Olds torus gasket question
I am installing my 1955 324 motor after rebuilding. my question is if i should use any type of sealer on the torus cover gasket, the manual says to use Vaseline to hold the gasket it place. Also should I use Loctite or some other type of thread sealer on the torus cover bolts and also on the flywheel to crankshaft bolts. Please advise as to what would be the best product to use.
thanks DaveT
thanks DaveT
I agree with Tedd. If the mating surfaces are "correct" and clean and the gasket is undamaged, there should be no need for any sealant. Page 3-36 of the 1955 Oldsmobile Shop Manual discourages the use of any sealant at this location. I did mine without sealant, and it held tight.
aussiemobile
February 15th, 2013 07:31 AM
harry k
November 21st, 2012 08:54 AM
dallasite21
June 20th, 2010 05:37 AM
