Carburetor
Old March 25th, 2018, 04:59 PM
FTolliver's Avatar
Carburetor
Good evening, I have a question for you. I have a 1961 Dynamic 88, 394, 2 barrel, carb. Iam going to upgrade to a 4barrel. What is recommended? I know work has to be done to make an Edelbrock function properly. I have a stock 4 barrel intake.
FTolliver is offline
Old March 25th, 2018, 05:49 PM
Tedd Thompson's Avatar
The easiest would be a Rochester 4gc, that's what they came with.If you can get the carb linkage for the 4 bbl the swap would be even quicker. .... Tedd
Tedd Thompson is offline
Old March 25th, 2018, 06:10 PM
FTolliver's Avatar
Thank you.
Old March 26th, 2018, 01:19 AM
shiftbyear's Avatar
Although Tedd is correct, I like the latest design from Edelbrock AVS2 series, with electric choke and 2 cfm options, it seems like a good carb. I'm a Quadrajet lover, but the on your application the Edelbrock would be my first choice. Good luck with your conversion.
http://www.edelbrock.com/automotive/...ors/avs2.shtml
shiftbyear is offline
Old March 26th, 2018, 05:06 AM
FTolliver's Avatar
Carb. thoughts
Thank you.
Old March 26th, 2018, 05:54 AM
Doesn't your Dynamic 88 have the Slim Jim Rotohydramatic transmission in it? If so switching to an aftermarket carb will be rather difficult. You would have to make sure the manual throttle valve lever was setup correctly. That transmission does NOT tolerate misadjustment. Be careful!
Olds64 is offline
Old April 1st, 2018, 09:13 AM
FTolliver's Avatar
Thank you. I will try and not mess this up.
Old April 2nd, 2018, 02:02 AM
Ozzie's Avatar
If you've got the Hydramatic, the easiest approach would be the Rochester 4GC and the original 4GC linkage, unless you are really good at linkage fabrication. If you have the 1961 Oldsmobile service manual and would like to see what is involved, look on pages 3-73 through 3-76. It's nothing for a novice to tackle. Even with the original linkage, sometime it's a challenge to get that Hydramatic to shift properly.
Ozzie is offline
Old April 2nd, 2018, 07:07 AM
FTolliver's Avatar
carbureator
I do have the shop manual as well as the chiltons. I will read up on this before i dive in. Thank you.
yeahbuddy
June 1st, 2010 05:38 AM
Gaz Hog
October 17th, 2007 07:26 AM
TheRuss
July 25th, 2007 01:22 PM
olds307owner
May 23rd, 2007 09:01 AM
ViceGuy
March 25th, 2007 01:43 PM
Quick Reply: Carburetor
