'70 Cutlass Shift Lever End Assembly?
I have a '71 tilt column shift in my '70 and want to change the shift lever to the correct '70 shift lever with fluted metal handle and woodgrain-look end cap.
How is the shift lever end cap and metal handle attached to the shift lever? Is there a threaded washer nut that fits inside the hollowed out rim of the rubber end cap?
The '70 fluted metal shifter handle is shorter in length (about 3/8") than the smooth shifter handle on the '71/'72. I'm aware that the column shift lever for the tilt column is different than the non-tilt shift lever.
NOTE: I posted this question in the "Interior" section. Mods, please delete my thread there.
Toms cutlass
February 24th, 2018 09:36 AM
Rocketbrian
October 2nd, 2013 10:18 AM
