Hood hinges
Old February 14th, 2018, 02:36 PM
scrappie's Avatar
Hood hinges
Anybody familiar with these? Maybe pontiac GTO?
scrappie is offline
Old February 14th, 2018, 06:01 PM
Yellowstatue's Avatar
Maybe '68 Cutlass, for sure, for sure.
Yellowstatue is offline
Old February 14th, 2018, 06:28 PM
scrappie's Avatar
Thx It makes sense they are Olds
scrappie is offline
Old February 15th, 2018, 03:28 AM
rob1960's Avatar
I've seen hinges like yours on a few '68s, including my own '68 442. The thing that's confusing is that the service manual clearly shows '68s(A,B &C bodies all use the same hinge for '68) using 3 bolts on each hinge to the underside of the hood plus a little spacer that goes on the rear bolt, yours only have 2 like mine. My hood has the 3 holes on each side, like every '68 hood I've seen. I was told by someone else that they might be off a Pontiac??, Mine fit fine but I'm thinking of modifying them by squaring up the rounded end with a little welding & adding the 3rd slotted hole. I found a pic online of a pair of '68 hinges,you can see the 3rd slotted hole at the rear. I've never found anything about maybe a 1st or 2nd design on '68 hinges? My 442 is a Nov 67 Lansing car.
rob1960 is offline
Old February 15th, 2018, 04:39 AM
scrappie's Avatar
Thanks Rob, the hinges look to be the same. I was told they may be pontiac also but Im not sure? I only have 70-72 stuff to compare and Id like to be sure. Maybe Ill check out Pontiac parts and compare.
scrappie is offline
Old February 15th, 2018, 04:44 AM
allyolds68's Avatar
Early 68's only have two holes. The rear hole with the spacer was an early assembly manual change
allyolds68 is offline
Old February 15th, 2018, 06:39 AM
scrappie's Avatar
Thx Mike,
I wonder if they are interchangeable with Pontiacs? because that seems to come up. The pic looks just like them.
scrappie is offline
Old February 15th, 2018, 08:03 AM
allyolds68's Avatar
Originally Posted by scrappie
Thx Mike,
They might be. The GTO/LeMans seems to use a two hole (in the fender) hinge from 68-72. It looks like there’s only two holes on the hood though.
They’re $77 each from Ames Performance (without springs) which is still more than you can buy a used set of 68 Olds hinges for.
georgiaboy697
July 2nd, 2010 09:23 PM
Eightupman
February 1st, 2010 10:23 PM
Jolly Green
August 2nd, 2008 12:51 PM
chuffman
June 6th, 2007 09:23 PM
Quick Reply: Hood hinges
