Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
62 starfire
Old February 9th, 2018, 02:58 PM
Oldpac62's Avatar
62 starfire
Need some help I am replacing upper and lower ball joints on both sides I got upper ball joint drilled and new bolts I can't get old pivot bushing off shaft took out bolts and inner slotted sleeve on both ends still can't get bushings to come off. ALSO CANT GET LOWER BALL JOINT OUT of control arm I'm trying not to cut rivets and drill what am I doing wrong? I've read all the books I can thank you mel
Last edited by Oldpac62; February 17th, 2018 at 04:56 PM. Reason: Problem is solved
Oldpac62 is offline
1962oldsguy
May 19th, 2019 08:08 PM
Kyle's 77 Cutlass
January 1st, 2014 09:06 AM
Oldssupreme
February 3rd, 2013 06:26 AM
Oldssupreme
February 3rd, 2013 06:24 AM
slhandpaz
October 24th, 2005 05:17 PM
Quick Reply: 62 starfire
