T-stat housing
Old January 13th, 2018, 04:29 AM
scrappie's Avatar
T-stat housing
Is a T-stat housing for a 70 w-30 unique or are all housings for the 455 the same? I know there are cast and aluminum versions of each.
scrappie is offline
Old January 13th, 2018, 08:14 AM
They are all the same. There were two versions, the die cast version with the short bypass barb that used the "J" shaped hose and the cast iron version with the steel "J" tube that used a short straight hose to the water pump.
This was a factory change in the late 1970 timeframe - die cast up to that point and cast iron after. Once the die cast housings were purged from the parts network, there was a service replacement kit with the cast iron housing for retrofit on earlier motors with a corroded or leaking housing. Here is a detailed thread about the topic.
This factory engineering order provides more detail for the change in the 1971 model year. Note that the factory authorized the use of die cast housings on 1971 non-A/C 350 motors to use them up. Note also that this is yet another example of how Olds ALWAYS documented production line changes and non-standard configurations. People who say "anything was possible" to justify a one-of-none car are blowing smoke.
joe_padavano is online now
Old January 13th, 2018, 10:36 AM
scrappie's Avatar
Thanks Joe, good stuff.
scrappie is offline
Partagas
January 8th, 2016 06:50 AM
BeenThere
February 10th, 2013 07:03 AM
66-3X2 442
January 1st, 2013 08:15 PM
Al Graaf
April 15th, 2012 04:38 AM
GoldOlds
October 24th, 2007 04:38 AM
Quick Reply: T-stat housing
