Rear spring help - ClassicOldsmobile.com
LinkBack Thread Tools Search this Thread
Old December 29th, 2017, 01:19 PM   #1
Rear spring help
Hi guys, Iím in the middle of going through troubleshooting my rear suspension noises on my 67 Cutlass. So far Iíve changed out dead air shocks and replaced all the body mounts. I also temporarily removed a sway bar that was missing a bolt. A random banging noise has been eliminated but there is a TON of annoying squeaking! You literally cannot drive the car over 25 mph without going insane. I bought an original chassis manual but the section is not showing me everything. I see that the springs have NO rubber isolater top or bottom. I want to address this, but can someone please tell me WTF is going on in my trunk? What is up with the spring mounting and how is it supposed to be? I can take pics from underneath if needed. Thanks
1967Supreeeme is offline   Reply With Quote
Old December 29th, 2017, 01:21 PM   #2
Cutting torch hole?
Factory? Looks like a hack, but why?
Old December 29th, 2017, 01:39 PM   #3
There are rubber isolators that go on top of the springs.
https://www.summitracing.com/parts/m.../model/cutlass
Been a while since I did my body mounts, what does the bolt in the trunk holes attach to?
oldcutlass is offline   Reply With Quote
Old December 29th, 2017, 02:47 PM   #4
It looks like the bolt in each hole is holding the top of each coil spring to the car. I think there was a large nut and washer, but I didnít see any rubber pad. When I did the shocks, the rear end lowered down with the shock bolts removed. The springs stayed attached at the top. I did every body mount, not a single one gave me any trouble. The car used the entire kit PLUS the extra 2 ďsupplementĒ ones and I did not have to remove these 2 large bolts. All bolts I removed were from underneath the car, except the ones by the radiator. The chassis is incredibly dry, and I donít see any signs of accident. There looks to be the ďtype OĒ 12 bolt cover rear end and and normal control arm setup. Were there studs that snapped off and someone replaced with bolts? You can see these bolts are next to the wheel wells where, at least I think, the coils are supposed to sit on top of the axle.
Old December 29th, 2017, 02:54 PM   #5
There should be no bolts that attach the springs to the body. On a 66 there was a clamp on the diff perch. Post some pics when you get it apart.
Old December 29th, 2017, 03:40 PM   #6
Are you sure the rear suspension bushings are in good shape? Worn bushings can also cause squeaks.
joe_padavano is offline   Reply With Quote
Old December 29th, 2017, 04:08 PM   #7
Quote:
Hey Joe, I am going to tackle them next. I just wanted to go after obvious hacks and missing rubber isolators first. Itís nice having the manual now before I tear stuff apart.
Old December 29th, 2017, 07:08 PM   #8
steverw's Avatar
Like Eric said there are no bolts or clamps that hold the springs in in a 67. You have to set the springs in, raise the rearend up, attach the shocks, and this usually is enough to hold the springs until it is lowered to the ground. The springs need to be clocked properly while up and easy to turn. I think its so the end of the pigtail is parallel with the axle if I remember correctly.
Good luck
steverw is offline   Reply With Quote
Old January 2nd, 2018, 03:03 PM   #9
Quote:
Good luck
Ok, this makes sense. When I removed the old air shocks, I compared them to the new stock replacements. The air shocks were several inches longer at extended length. Maybe someone was going for that super raked look and with the *** end way in the air, this was the ďfixĒ to keep the springs from falling out. Once I got the new shocks in place, there was hardly any slop where the springs sit on the axle.Iím picking up new isolators tomorrow, Iíll report back once I unbolt the springs and get some rubber back up there.
Old January 7th, 2018, 11:04 AM   #10
Old January 7th, 2018, 11:11 AM   #11
So, once I removed the nuts and bolts, I was able to pull the springs out with the shocks still attached. I took pics showing the lower mount too, just a cup that the spring sits on. Looks to be correct for a 67?
Both springs were the same length, about 12 5/8Ē. Seems pretty short. Are these the wrong springs? Or have they been heated to lower the car?
Old January 7th, 2018, 12:47 PM   #12
If you could pull the springs with the shocks attached you have shocks that are too long or springs that are too short. Bets are on the springs.
Old January 7th, 2018, 12:57 PM   #13
those look like Moog cargo coils, the ones listed for a 67 cutlass are CC501
I ordered a set of those for my 66 by mistake and they look just like the ones you have.
12.63 inch free height
8 inch compressed height
http://www.moog-suspension-parts.com...il_springs.asp
nicks1966 is offline   Reply With Quote
Old January 7th, 2018, 01:18 PM   #14
This is a great reference chart of all Moog coil springs. You can do some quick measurements to determine which spring you have. You'll find that a lot of the repro places reference the Moog pn's.
Old January 7th, 2018, 01:37 PM   #15
https://www.summitracing.com/parts/gab-81514
Hereís the shocks Iím running, seems to fit like I would expect. They only need to be compressed a little to line up the lower bolt to the mounting hole.
Old January 7th, 2018, 01:51 PM   #16
Yeah, Moog sells stock replacement at 14.29 inches free height (6321). This sounds about right. If someone has a nice used set Iíd be willing to buy them, you can shoot me a message. Probably put up a want ad
Old January 7th, 2018, 02:09 PM   #17
You can get a brand new pair through rockauto for $49.79.
http://www.rockauto.com/en/parts/moo...il+spring,7512
Old January 7th, 2018, 08:43 PM   #18
At that price I went ahead and ordered them. Canít wait to see the improvement. 😀
Old January 12th, 2018, 04:48 PM   #19
Got the new springs installed and the car rides WAY better. Thereís still some noise going on, but not as bad. Iíll be checking out the control arm bushings and maybe exhaust rattling at high speed when I put my foot in it. Thanks guys
Old January 12th, 2018, 05:09 PM   #20
Glad your moving in the right direction.
Old January 12th, 2018, 08:31 PM   #21
After looking it all over I think I figured out what was going on.
One owner had air shocks installed, or dealer maybe...
Someone then added a sway bar (donít see factory boxed control arms....
Then, some asshat decided they wanted it lowered, left the dead, super long air shocks in place. Heated the springs at the axle end ( on closer inspection they look darker at the bottom and coils are too close together compared to the replacements)
Since they didnít realize the spring length is CRITICAL to keeping the rear end on the ground, they attempted to ďfixĒ the situation by bolting the springs in place.
Running it like this (with a loose sway bar too) probably destroyed the control arm bushings. No doubt, they are probably f**ked.
Thread Thread Starter Forum Replies Last Post
spring height and spring pressure johnnyjaws Big Blocks 2 February 23rd, 2015 04:30 PM
rear coil spring removal cola Chassis/Body/Frame 23 May 14th, 2014 08:12 PM
1965 vista cruiser rear coil spring help request krauser65 Parts Wanted 0 April 29th, 2014 08:26 AM
Coil spring vs. leaf spring suspension Longhorncutlass General Discussion 4 March 2nd, 2009 01:53 PM
rear spring Isolators Want-A-Vert Chassis/Body/Frame 1 March 23rd, 2007 03:22 PM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content Copyright © 2017 by Internet Brands, Inc.
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
