Won't start after sitting several days.
I have found that if I fire my car up every day or two she fires right up. Two or three pumps on the pedal and fires up, no issues, no problems. If she sits more than 2 days she will not start without me dumping some fuel into the carb. Once I do that she fires and runs great. I suspect it is the choke on the carb. Any suggestions?
by your description I doubt it's your choke settings
well plugs under carb float bowl are likely leaking your fuel away and the accelerator pump is probably not sealing very well either. crank the car for ten seconds and then lightly pump the accelerator 4-5 times and see if it starts.
common problem with Q-jet carbs.
Mine is similar start every day no problem, sit for a week I crank for3-5 seconds, wait 3-5 seconds, repeat 2 more times w a couple pumps of the pedal, I thought it might be the well plugs as well so I took the carb off and let it set on the bench full of fuel, after a day the well plugs were dry. Forum wisdom suggests the fuel today evaporates more easily, so I just live w some extra cranks if it sits a while. This is w a qjet.
BEFORE you waste a lot of time and money worrying about the well plugs, try a simple test. Pull the carb off the car and prop it up on the bench over a sheet of paper. Fill the float bowl through the vent. Let it sit overnight. If the paper is NOT wet and stained, the well plugs are NOT leaking and your problem is elsewhere.
Ever since Doug Roe wrote about these, the Qjet well plugs have been blamed for every hard start problem. The reality is that this problems primarily affects the 1966-67 Qjets with the sheet metal plugs. By 1968 the design was changed to the spun-in aluminum plugs that RARELY leak. Run the easy test before wasting time and money. Your problem is far more likely due to a weak check valve in the fuel filter and/or fuel pump. You DO have the stock fuel filter with a check valve installed, don't you?
In any case, it costs nothing to test for the leak with the carb off the car. Why wouldn't you do that FIRST?
Isn't the black foam gasket supplied in the rebuild kits supposed to take care of any potential seepage in the well plugs? Not saying they ever leak (I've never experienced it) - just an observation about the parts in the rebuild kits.
Joe, I should introduce myself first (Jerry), My 66 Toro exhibits the problems of hard starting after sitting overnight and yes I do have the sintered stock fuel filter and a new fuel pump, but what &(where) is this check valve your talking about? The Carb was just completely overhauled by "Carb Rebuilders" in Oshawa Canada. The well plugs were sealed with JB weld and all fixes were applied including a new leather pump. I have not tried to let the carb sit on the bench overnight yet, but I am going to do this tonight because I am at my wits end with this car. Not only is it hard starting after sitting but does not seem to have the power it should have. It has a new rebuild to factory spec and idles very nicely, but when I put pedal to metal it falls flat. I just put a new coil in it (MSD Blaster II 8202) hoping it was weak, but no difference.
That's the intent of that piece of foam, but I've never been convinced of it's effectiveness.
I agree with Joe about the well plugs. After 2 or more days are you getting a fuel shot from the accelerator pump when you move the throttle with the engine off and cold? Does the choke flap close like it's suppose to? If the accelerator pump cup is not ethanol resistant it may distorted and not giving you a good shot of fuel. Good luck
The fuel pump was the problem!!
I hope this helps
Eric
Tedd Thompson
December 20th, 2016 08:29 AM
mryoung4815
August 19th, 2011 11:51 AM
