Ram air
I'm in the same boat.......
Thanks for the info Joe. I have a .PDF version for my '68, but the page / figure for the OAI scoop installation seems to be missing. Seems that somewhere in the distant past I stumbled across some templates or measurements showing exactly where to cut the 4" holes for the scoops. But I can't seem to find it now. In the mean time, I'm using any reference photos I can find.
I'm adding the '68 OAI setup (also from TPP) to my 350-2bbl (it WILL be a 4-bbl in the not too distant future, but for now I'm using a carb adapter to fit it to my 2 bbl........go ahead and laugh). Any how, discovered I needed a new PCV vent tube from the air cleaner filter to the valve cover since the old one "twists" the wrong way. Now that I have the correct one, discovered that the air cleaner is sitting ~1" higher apparently because the tube is too short. I'll rig something for that until I get the engine rebuilt w/ a 4-bbl.
What HAS surprised me is, I purchased a new air cleaner "pie tin" since it is larger than the one used on the 2-bbl air cleaner. However, the chrome retainer from my 2 bbl is ~ 1" too small in diameter to retain the larger 4-bbl pie-tin on the 4-bbl dual snorkel air cleaner. I've shopped around and can find only one size retainer. Who makes a larger retainer for the 4-bbl pie tins?
Aye, description:
Air Filter Plate Chrome Retainer, 66-70 Toronado, 1968 OldsChrome plated retainer used to hold down the aluminum air cleaner top plates on 1968 Oldsmobile models and 1966-70 Toronado.
UNLESS, there actually ARE two different sizes of chrome hold-downs, and NOBODY repros the smaller one for the 2-bbl air cleaners. However, Fusicks also sells the 2-bbl pie tin, why would they not also carry a hold-down for that if it is, in fact, smaller than the 4-bbl hold-down? It doesn't make any sense.
If someone DOES have a FPR680, what is the diameter of it?
Maybe I'll just email Fusicks and ask.
That was quick:
I'm pretty sure the 2-bbl hold down measured only ~ 3.25". Once I confirm I'll be ordering the FPR680.
Hi John,
The diameter of the FPR680 is 4 ½”.
Thanks,
Kevin
Fusick Automotive Products
Thanks,
Kevin
I'm hearing that the 68 and 69 under bumper scoops are different? The Fusick photos show a size change between years. Apparently the 69 version is better? Anyone have dimensions? I'd like to add OAI to my car and I would like the better design of the two.
The 69 scoops are about a 1/2" taller than the 68 too (guessing 2" on the 68s, 2.5" on the 69s). 24 in^2 (68) vs. 20 in^2 (69). Maybe the '69s are a full inch taller, making them also 24 in^2. Hard to claim one design is more efficient or "better" than the other IMO.
OP, use the scoops that are correct for your year.
..........Just my two cents worth.
Fender Skirt hole (passenger only)
