Motor mount bolts
Old April 28th, 2017, 04:23 PM
servexcell's Avatar
Motor mount bolts
Can anyone tell me the bolts sizes for the engine mounts
thanks Bruce
servexcell is offline
Old April 28th, 2017, 04:52 PM
2blu442's Avatar
Hi Bruce
So are you needing specs on the bolts that hold the rubber mount to the engine? Or one of the other ones?
John
2blu442 is offline
Old April 28th, 2017, 08:07 PM
servexcell's Avatar
John
I need specs on the ones that bolt to engine block and the 3 that fasten to the frame.
Thanks Bruce Black
Old April 29th, 2017, 02:18 PM
2blu442's Avatar
OK, I pulled these from parts cars so there's a chance they've been changed over the years. But they fit and look correct. The two that attach the motor mount to the side of the block are 7/16" bolts and are 1 inch long. The threads are 14 per inch which I think is a common pitch. The three bolts that hold the metal perch to the frame cross member are 3/8" bolts and 1 inch long. These have a nut with a lock washer on the engine side of the cross member. Let me know if you need anything else Bruce.
John
2blu442 is offline
nolabigdawg
October 25th, 2014 11:50 AM
AZ455
March 14th, 2012 06:51 PM
AZ455
December 30th, 2011 10:01 PM
rhaberm
September 26th, 2010 03:55 PM
bittersweet71
August 16th, 2010 07:01 AM
Quick Reply: Motor mount bolts
