Dash pot - ClassicOldsmobile.com
LinkBack Thread Tools Search this Thread
Old April 19th, 2017, 07:26 PM   #1
Dash pot
I need a dash pot for a 70 cutlass with a 2barrel. Anybody make them? What it does is when i'm at a light for awhile, It just dies. Then of course it hard to start.
Rick P is offline   Reply With Quote
Old April 20th, 2017, 08:31 AM   #2
friesjh's Avatar
Please someone correct me if I'm wrong, but I do not believe the dashpot is your problem. Sounds like more of a carburetor issue.
friesjh is offline   Reply With Quote
Old April 20th, 2017, 09:17 AM   #3
jensenracing77's Avatar
The dashpot is to prevent the throttle blades from closing all the way to fast. If your problem is when sitting then the dash pot is not the problem.
jensenracing77 is online now   Reply With Quote
Old April 20th, 2017, 12:32 PM   #4
Tedd Thompson's Avatar
Could be many things but air leak somewhere in the fuel line system seems possible or a fuel pump valve that is going bad.You really need to do some investigation before we can help. Have you taken off the air cleaner and checked to see if there is fuel in the carb bowl( pump the throttle to see if the accelerator pump has fuel to it).You need to sort out whether it's fuel related (probably) or something else.... Tedd
Tedd Thompson is offline   Reply With Quote
Old April 20th, 2017, 02:21 PM   #5
Ok, I'll look into it further. Thanks for responding.
Old April 20th, 2017, 08:40 PM   #6
Quadrajet Power's Avatar
Dashpots to my knowledge are no longer being produced. You would have to find a NOS unit.
Quadrajet Power is offline   Reply With Quote
Old April 21st, 2017, 08:49 AM   #7
I don't think a dash pot does do much more than slow down the linkage to the carb on deceleration. It was the first of the steps the car company's did to help emissions.Could be wrong on this, all my cars are ether old enough to be emission free or fuel injected.... Tedd
Thread Thread Starter Forum Replies Last Post
Quadrajet Dash Pot for 1970 350 Pacecar Parts Wanted 0 August 7th, 2012 08:03 PM
Dash Pot Needed harleyrules Parts Wanted 3 August 22nd, 2011 09:24 PM
71 455 dash pot fjross Parts Wanted 8 December 19th, 2009 08:17 AM
looking for a dash pot 70-442-455 Big Blocks 11 July 28th, 2008 10:23 PM
carb dash pot vacuum dynamic88 Big Blocks 7 July 30th, 2007 06:39 PM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content Copyright 2017 by Internet Brands, Inc. We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
