Valve Cover Recommendations
Old March 23rd, 2017, 04:32 PM
Propaneking's Avatar
Switch the 350 out for a 455. Have clearance issues. Looking for recommendations on Valve covers. Coolness and Correct Height help. Thanks
Propaneking is offline
Old March 23rd, 2017, 07:40 PM
Nothing like factory notched ones. I'm sure someone here has some to sell you.
Koda is offline
Old March 23rd, 2017, 07:41 PM
72 Olds CS
RetroRanger's Avatar
where are the clearance issues at the AC box, Brake booster or inside the valve cover ?
I swapped my 350 for a 455 and have the stock notched BBO a body valve covers on w no issue.
RetroRanger is offline
Old March 24th, 2017, 08:02 AM
rob1960's Avatar
If you want "coolness" find a set of the '73-'74 covers that have "Oldsmobile" stamped in them. They have a narrow profile all the way down instead of a "notch" so there is no fitment problems at all. They show up on epay all the time & I'd bet someone here has a set for sale.
rob1960 is offline
Old March 24th, 2017, 02:48 PM
Telling us the year, model, and with or without A/C would help get a useful answer.
joe_padavano is offline
Old March 24th, 2017, 02:59 PM
Thanks for the responses. 72 Cutlass with ac removed. Brake and heater normal tight fit areas. Just don't see much for sale on the market I like thats cool. I see a number of covers available that look "cheap". Love the script ones but way too tall. I'll keep looking.
Old March 24th, 2017, 03:11 PM
A/C removed, but heater normal tight fit? What does that mean? Do you have the stock A/C HVAC box? A stock metal heater-only box? The aftermarket A/C delete box? Each provides different clearance.
Stock 11" power brake booster? Something smaller?
How are the accessories mounted? Alternator on the passenger side or driver side?
These questions all factor in to which covers fit. The driver side alternator bracket won't clear anything taller than stock. Same for the 11" brake booster and the stock A/C HVAC box. If you want taller aftermarket covers, go to manual brakes or a hydroboost. The stock metal heater-only box clears the regular finned aluminum covers (Holley/Edelbrock/Mickey Thompson etc). The stock passenger side alternator bracket clears these also.
The "script" valve covers referred to above were not the tall aluminum ones but the lower one in this photo, used in 1973-74 only. They clear any stock configuration of brackets/HVAC/booster.
Old March 24th, 2017, 07:21 PM
Its a stock ac Hvac box, stock power brake booster. Alternator is on Driver Side. If anyone has a pair of the 73-74 script valve covers what would you want for them?
Almond900
November 1st, 2016 09:29 PM
Almond900
February 26th, 2016 02:56 AM
dnohe
September 23rd, 2014 03:01 PM
19cutlass71supreme
February 19th, 2014 07:41 AM
VikingBlue
June 4th, 2010 03:07 AM
Quick Reply: Valve Cover Recommendations
