1984 olds delta 88 307 starting problem
Old July 30th, 2016, 09:23 AM
Harold Pierce's Avatar
hey everyone I'm new to this , so I have a question I have a 1984 olds delta 88 royale brougham, 307, it was running fine parked it went out the next morning and no start, will turn over but wont start, ive replaced the following, carb,plugs,wires,coil,ignition control module,cap,rotor,starter,battery,electronic spark control,, it does have a computer on it, its throwing a code 12? I checked for fuel and fire, its getting fuel, weak spark one time and blue spark another time. any and all help would be great , thank you
Harold Pierce is offline
Old July 30th, 2016, 10:06 AM
Code 12 simply means the system is operating normally.
Try running a temporary wire from +12v to the BATT terminal on the distributor cap and see if it starts. If not, the problem is in the distributor. If it does, the problem is between the ignition switch and that terminal.
joe_padavano is online now
Old August 1st, 2016, 10:58 AM
4 Barrels of Laughs
quaddriver's Avatar
Location: I moved to pittsburgh so I can be near Primantis
fuel, air, compression, spark - it has to run. has no choice.
so: squirrel nest in air cleaner? no = likely getting air
fuel smell? make sure the pump is pumping. if in doubt, here is a cheap trick: while cranking hold a propane torch UNLIT over the carb intake and wide open. if it then starts you are getting zero fuel.
spark: easiest way to test is a timing light on a plug wire and crank it, no flash = something somewhere in the spark circuitry.
lastly: computer. even if you fry the ecm, they can limp. all the ecm does is control the mixture solenoids in the carb, which really dont do jack other than go up and down real fast. unplugged, it will still run somewhat.
so assuming it is not real bad like a broke timing chain, check those items and report back.
quaddriver is offline
mthompson1951
November 5th, 2016 12:27 PM
eazy p
June 25th, 2013 08:51 AM
bccsrc
November 29th, 2011 11:08 PM
84oldsDelta88
20
April 20th, 2010 01:46 PM
jk121
May 14th, 2007 01:49 PM
Quick Reply: 1984 olds delta 88 307 starting problem
