Vin tag placement
Old June 3rd, 2016, 04:11 PM
70convert's Avatar
Vin tag placement
cant seem to find a pic or any threads with this answer.
Is the tag supposed to be on the top or under the attachment tabs or does it make a difference.
70convert is offline
Old June 3rd, 2016, 05:13 PM
2blu442's Avatar
Well, one of the guru's will have to speak up to say for sure. I checked a 1968, 1969 and two 1971's they all had it on the underside of the dash tabs. But I don't know if that's true with all or just happens to be what I've got.
John
2blu442 is offline
Old June 3rd, 2016, 05:25 PM
Gary M's Avatar
Here's my 72
From the bottom under the dash.
Gary M is offline
Old June 3rd, 2016, 07:05 PM
70convert's Avatar
Thanks guys, so far looks like its I have to move it under to make it correct. I had to replace the dash so I took the tag from my original and should have asked first before putting it back, it was about 4 years ago and probably the only thing I didn't take a picture of. Mind is sure not what it use to be.
Old June 3rd, 2016, 07:08 PM
There should also be a plastic surround on the upper dash to frame in the VIN tag so the rivets don't show.
Allan R is offline
Old June 3rd, 2016, 10:20 PM
"Trying to fix her right"
dfire25's Avatar
Any truth to the rumor that Lansing built cars were pop riveted from underneath? Here's a pic of mine.
File Type: jpeg
dfire25 is offline
Old June 4th, 2016, 04:11 AM
Octania's Avatar
That has been my experience, yes.
I believe the assembly manual has a great deal of specific information about the VIN tags, down to the exact size of the tag, and the specific shape of the characters, such as the flat-top "8".
Octania is offline
Old June 4th, 2016, 05:17 AM
Gary M's Avatar
It's hard to tell in the picture I posted but mine is riveted from the bottom too.
Gary M is offline
Old June 4th, 2016, 06:55 AM
The assembly manual specifically says that rivet head orientation is optional.
joe_padavano is offline
Old June 4th, 2016, 05:11 PM
marxjunk's Avatar
it depends who attached them..ive seen pics of one was UP and one was DOWN..they went in before the windsheild..and theres a whole bunch thats showed up the same way..
its what ever the line worker did..day to day...and what was easy...
marxjunk is offline
Old June 4th, 2016, 05:46 PM
70convert's Avatar
since the tag is installed under the tabs the pressure from pushing from below might make it easier to install. thoughts????
Old June 4th, 2016, 05:50 PM
70convert's Avatar
Allan my plastic piece broke when I took it off so i ordered a new one from inline tube with the many other parts. I think i own 20% of inline by this point
Old June 4th, 2016, 06:49 PM
marxjunk's Avatar
ive seen a ton from the bottom..id say what ever you feel good with is right..
marxjunk is offline
Old June 4th, 2016, 06:57 PM
Gary M's Avatar
If most are from the bottom then in the interest of not creating doubt later you should just copy the norm. Apparently ebay is selling the rivets.
Gary M is offline
Old June 5th, 2016, 11:21 AM
allyolds68's Avatar
The story that daveh has told said that the windshields were in place in Lansing so the VIN tags were installed from underneath. BOP plants installed the windshields last so the VIN tags rivets were installed from above
allyolds68 is offline
Old June 6th, 2016, 04:46 PM
70convert's Avatar
pardon my ignorance but what are BOP plants
Old June 6th, 2016, 05:07 PM
BOP is an acronym to describe the divisions of GM
B-Buick
O-Oldsmobile
P-Pontiac
When I worked in vehicle merchandising back in the late 70's the acronym was longer
BOPCK
The C is Chevrolet
The K was Cadillac
Now the GM corporate branding is a Chevy, Buick, Cadillac or GMC.
Gone are Oldsmobile (sad), Pontiac and Saturn (yay). Less choice, it's all about profit and jobs IMO.
Allan R is offline
Old June 29th, 2016, 04:23 PM
70convert's Avatar
knoggin
April 17th, 2014 01:48 PM
DRXOLDS
April 8th, 2011 05:29 PM
rallygreen
September 15th, 2009 04:02 PM
Nailhead 88
February 6th, 2008 06:12 AM
DesertToro
January 16th, 2007 07:10 PM
Quick Reply: Vin tag placement
