When did olds put the highbeam switch
That is a good question.
Are you sure your steering column is original to your car?
Gm often offered an option on one make and would soon make it available to other lines of its products.
Specific to your Olds related question, I can't answer it. Someone with a stack of Oldsmobile factory manuals can tell you for sure.
No idea if the column is original, it matches the rest of the interior blue, but that don't mean much..
but it is correct for a floor shifted car(or it would seem) as there is no stock/mount for a column shifter..
The dimmer switch on the column was part of the Salon option since it came out, Pontiac Grand-Ams had it also. My girlfriends 43k original '76 Salon has the column dimmer like it should & it has a rubber plug in the carpet where the floor dimmer would have been.
My 1975 I had in the early 90's it was on the floor, but it was a base car I'd guess, 260v8 and bench seat, and well that was it.
tcolt
January 19th, 2018 09:35 PM
safray
June 9th, 2016 08:22 AM
NewOldsGuy
January 3rd, 2011 07:44 PM
