What are these and can I....
Old September 15th, 2016, 10:54 AM
CJG
CJG's Avatar
There is no vacuum running to this only the coolant hose. Can i replace it with some sort of 90 degree elbow to clean up the looks?
There is nothing that goes to this at all its just plugging a hole. Any reason i cant replace it with just a pipe plug?
CJG is offline
Old September 15th, 2016, 11:05 AM
The first one is a heater control valve used only on cars with A/C. If you do not have A/C, replace it with the special hose nipple with the restrictor.
The second is the Thermal Vacuum Switch for the Transmission Controlled Spark system. Be very careful not to damage that unit when you remove it. It is not reproduced and is sought after by restorers.
joe_padavano is online now
Old September 15th, 2016, 12:30 PM
CJG
CJG's Avatar
Awesome thanks!
CJG is offline
Old September 26th, 2016, 06:02 PM
CJG
CJG's Avatar
Ok, so we kind of broke the heater control valve while trying to install the trans dipstick tube. Oreillys has some nipples similar to the one above, however they are just wide open, no restriction. Is there a reason why there needs to be a restriction inside?
CJG is offline
Old September 26th, 2016, 06:44 PM
Indy_68_S's Avatar
Originally Posted by CJG
....... Is there a reason why there needs to be a restriction inside?
I'm purely guessing here, but on my '68 non A/C there is NO coolant/heater valve. It was this way from the factory for non A/C cars and has the 'restricted' nipple. Hot water is always circulating (albeit restricted) thru the heater core. I suspected the restriction was to keep the cabin livable on hot days!
Indy_68_S is offline
Old September 26th, 2016, 06:48 PM
CJG
CJG's Avatar
I do not even have a heater core or any of the ductwork or any of that in the car. I guess what I'm asking is if I can replace the valve with a screw in nipple that is just a wide open nipple like Oreilly s has or do I have to find one with the tiny restrictive hole like the one pictures?
CJG is offline
Old September 26th, 2016, 07:32 PM
Indy_68_S's Avatar
Did a little digging....
In A/C cars the control valve acts as the restrictor. Non A/C depend on the nipple restrictor.
Looks like the restriction has a purpose. The main issue seems to be sound/noise of the coolant rushing thru.
Example here...
https://classicoldsmobile.com/forums...tml#post361345
https://classicoldsmobile.com/forums...tml#post955933
I also found some chatter about slowing the flow to prevent over cooling of the back of the engine, but nothing definite.
I'd think you would be fine running it 'open'.
Old September 26th, 2016, 07:42 PM
CJG
CJG's Avatar
Awesome thanks!
CJG is offline
Old September 27th, 2016, 03:03 AM
If you don't have a heater core, just put a pipe-thread plug in it.
That'll "clean it up" better than anything.
MDchanic is offline
Old September 27th, 2016, 03:13 AM
CJG
CJG's Avatar
You mean an actual plug? Then if so can I just do away with the hose going from it to the water pump and cap off the nipple on the pump?
CJG is offline
Old September 27th, 2016, 05:39 AM
That's what the factory did for heater delete cars.
Old September 27th, 2016, 05:43 AM
CJG
CJG's Avatar
Ok that makes it easy. If we ever decide to run heat we can always put it back. Thanks!
CJG is offline
Old September 27th, 2016, 06:44 AM
oddball's Avatar
Joe, how are those restricted nipples installed? I'm not seeing an engagement surface for sockets or wrenches, maybe just a slotted top for a screwdriver? Seems a tall order for 3/4" NPT...
oddball is offline
Old September 27th, 2016, 07:07 AM
Shaking out the cobwebs..
midrange's Avatar
I used a drag link socket to install mine.
midrange is offline
Old September 27th, 2016, 07:32 AM
An excellent solution. A section of appropriate thickness angle iron also works.
Old September 27th, 2016, 01:00 PM
The restriction also acts as a pressure reducer to prevent the heater core from ballooning and rupturing.
Fun71 is offline
Jen
October 19th, 2012 01:33 PM
young olds
August 10th, 2011 11:37 AM
TRW
August 29th, 2010 05:20 PM
squirell
Body work
November 23rd, 2009 01:51 PM
gearheads78
July 14th, 2008 12:47 PM
Quick Reply: What are these and can I....
