Water pump bolts on BBO
Was replacing my water pump on my newly bought cutlass and the previous owner had incorrect bolts for the water pump. One bolt was missing and one was incorrect and was not even tight. Does anybody know the original sizes to these bolts so I can replace them. I will post a picture of the pump so you guys know which bolts I'm talking about. Thanks
The bolts I'm talking about is the one directly under the pump outlet and the bottom middle one. They are right next to each other. Any help would be great, thanks.
Inline Tube sells the hole set. Look under timing chain cover bolts. If anything you can see the correct bolts that are used and compair with what you have.
http://www.inlinetube.com/PDF%20cata...dsmobile04.pdf
Hmmm the long one with threads on both sides goes below the pump outlet? I remember that bolt when i took it out, it was in the hole right above the outlet. Sounds like mine were all messed up.
Nor Cal Andy
March 29th, 2012 07:27 PM
