Testing the sending unit on a '68 Olds 98
Location: Northern West by the grace of geography Virginia
Testing the sending unit on a '67 Olds 98
Hi guys... I'll be dropping the tank on my '67 98 Town Sedan in a week or two. Gauge sits pegged at 3 oClock.... way passed full.... constantly, until I unplugged it at the connector in the tank and grounded it, at which time it went to empty. Rehooked and it went back to 3 oclock.
I removed, cleaned and replaced the grounding screw at the tank to no avail... although I'm still a little dubious of it, so prior to tank droppage, I plan on grounding that with an alligator clip to the frame to be certain.
So... to the question... I very, very rarely use a multimeter, but would like to test the old canister type and see if I can make it work before I swap it for a non-canister type from Rock Auto.... which will work, but will likely float all over the place.
Can someone walk me through the tests I should do once I drop the tank, to see if mine can be repaired? Basically... what I should expect to see, what I should set my multimeter to and what I should connect it to, etc. Sorry that I need the handholding here, but it's been a while.... and of course, electrical stuff is pure voodoo.
Last edited by mikeamondo; March 31st, 2015 at 01:21 PM. Reason: Had the year wrong on my own car.. sheesh
Okay, here's your fuel gauge circuit:
+12V (Instrument Power) ------> Fuel gauge (Driver's side + terminal) -----> Fuel gauge windings -----> Fuel gauge (Passenger side - terminal) -----> Tan wire -----> Tank sender -----> Rheostat (0-90Ω) -----> Ground.
The sender should read 0 - 0.6Ω at E, 44.9-45.1Ω at ½, and 88 - 90Ω at F.
I received my new sending unit (1972 Lesabre) from Rock Auto for my '67 98. I think I have a solid grasp on the steps for the job and testing the old unit before replacement.
Now... is there a need for a special tool to remove the sending unit from the tank... to loosen the locking ring? If something else can be made to work, what is it? Thanks!
Mike
Mike
Mike
Mike
Not to be stupid... but a hammer and 'drift'? Do you mean just tap against the ring in the right direction until it starts to loosen? Maybe I'm visualizing this thing incorrectly.
Make sure to clean that area of the lock ring really well before removing it. Compressed air works well. I'm also nervous about working with gas & tanks & always use a hammer on a brass punch so as not to create any sparks on top of the tank. If no brass, maybe spray it down with water from a mister or something? Maybe too cautious but rather be that way than not cautious enough.
hmmm... good thoughts... I don't have a brass punch, but I bet I can find something plastic or rubber that will do the trick. Thanks for the advice... I plan on dropping the tank this weekend if I have her back from the mechanics following her rear end rebuild... if not it will be a couple weeks down the road...
68RocketAction
December 18th, 2014 11:19 AM
