Rocker Arms
I see you have not received any responses, probably because YellaTerra does not list any Oldsmobile specific rockers on their web site. You can search the forum for rocker arms and you will see that some people have had success using the Ford Windsor style rocker (stud mount) on their Olds with success. With a stud mount rocker you will have to use guide plates for the pushrods. Why not use the Harland Sharp pedestal mount for Oldsmobile or the Scorpion pedestal mount? Since these are Oldsmobile specific you can be assured that they will work. I personally would use Harland Sharp rockers. Also, not knowing what your cam specs and cylinder head type are makes it kinda hard to give a good recommendation! Help us to help you sir.
I think his point is that the Ford pedestal style rockers used on the later SBFs are very similar to Olds rockers. They mount with 5/16" bolts (just like Olds), they use an internal anti-rotation feature to eliminate the need for guide plates (just like Olds), and they have a 1.6:1 ratio (just like Olds).
I was just spit balling. The Yella Terra rockers are a nice pedestal paired shaft adjustable unit. Just thought maybe someone knew if the Ford crossed with the Olds. It looks like they discontinued the Olds line.
You could call and see if they'll sell you just a pair to mock up. I'm pretty sure the Harland Sharp pedestal rockers are just the Ford rockers, maybe the mini shaft has slightly different spacing. You have to shim them to get the valve stem sweep pattern at its best, Harland sells a taller pedestal you can buy separately.
The geometry isn't quite right on them, so it's definitely a Ford rocker casting. The pushrod cup isn't quite angled right, but it works at reasonable cam lift (0.550" or so).
I did notice that the H-S rockers have individually adjustable lash/preload, the Yella Terra do not...
