Question on crank case ventilation
I have a 65 cutlass with a 330. 45.000 miles, Had the upper end redone.
It is blowing oil out of the oil fill tube not much but thats
what it did before I had it done. Pvc valves did not exist then
The CVS works with original parts is connected . Is there a way
to stop this or convert it to a PCV.
Kevin
Kevin
Kevin
Kevin
Any source that taps directly into a manifold runner or the base of the carb. Typically this would be something like the power brake attachment. If your carb has a barb fitting that is manifold vacuum, that's fine.
Fresh air
'64 and '65 Cutlass had PCV valves!! PN 6420092 type 639 for V8...PN 6421971 for V6..you had me wondering there for a while, must have been a trick question.. Also the valve cover should hook into the air cleaner via a metal tube and a couple of gromets according to the parts book..
Need Air
The only hook up is from valve cover to air cleaner via a tube
with a A/C Delco part ( a little roundish piece with a flapper inside)
between the two, that part hooks to the rear base of carb.
No other holes in valve covers.
