Paint Codes from Build Sheet (Picture)
I am trying to decipher my codes off my 1980 Olds Cutlass build sheet. It is not as easy as my 1972 was to find online. I am trying to find a site that can help me.
OR if I could get the color that would be awesome.
Thanks.
Thanks.
Have you tried www.autocolorlibrary.com?
LW = 11 means lower body color is code 11, which is typically a white.
UP = CC -- I don't know if this means the upper body is a vinyl top with code C, or if the CC means clear coat.
ST = 63 means the strip color is code 63. You'll have to look this one up somewhere.
W = 11 means the wheels are code 11, white again.
Your local autobody supply store should be able to help you with the codes. Or any GM dealer. Or maybe even the Duplicolor display of touch-up paints at your local auto parts store.
Boiler_81
September 22nd, 2020 02:05 AM
