oil pressure sender
oil pressure sender
recently purchased a 1970 cutlass convertible, car has a 1970 455 installed from a 442,E heads rally pack gauges etc. oil pressure is erratic with needle bouncing all over the place. Who makes a correct replacement sending unit for this application... i believe it must be a 0-80 psi range? in the mean time i'm going to tee off the elbow and install an autometer backup oil pressure gauge ...any advice would be welcome thanks
StickW31
January 7th, 2013 08:51 AM
