Odd part search: reinforced 90deg hose bend
Old November 15th, 2016, 07:13 AM
oddball's Avatar
Curious if anyone has seen a part like this. The fluid cooler I'm using has an outlet pointed downward and ends up only 3" or so from the bottom of the core support. I have a 3/8" hose connected to it, but the bend is a little tight and the hose wants to collapse.
I'm looking for the same thing as a 90deg PCV elbow commonly seen on the parts store wall, but needs to be reinforced and formulated to work as a tranny cooler fitting.
Unfortunately there's not enough tube to cut off the bubble and add an AN adapter. The tube is too thick to flare for an AN nut and there's not enough room to get a good flare tool on there.
Thanks!
oddball is offline
Old November 15th, 2016, 07:21 AM
Google is your friend...
http://hpsperformanceproducts.com/hp...ose-black.html
joe_padavano is online now
Old November 15th, 2016, 07:33 AM
oddball's Avatar
"Silicone hose is NOT compatible with fuel or oil."
I assume Dex/Merc still counts as an oil.
oddball is offline
Old November 15th, 2016, 10:14 AM
svnt442's Avatar
What trans cooler are you using?
svnt442 is offline
Old November 15th, 2016, 10:38 AM
oddball's Avatar
It's a three circuit unit from a Lincoln LS, nearly the size of an A/C condenser.
oddball is offline
Old November 15th, 2016, 01:56 PM
svnt442's Avatar
That seems a bit on the extreme side.
svnt442 is offline
Old November 15th, 2016, 01:57 PM
svnt442's Avatar
Like this one?
svnt442 is offline
Old November 15th, 2016, 02:31 PM
72 Olds CS
RetroRanger's Avatar
My 2000 new holland tc29 d uses a hose like joes picture coming out of the trans cooler don't know if that would work for you.
RetroRanger is offline
Old November 16th, 2016, 06:53 AM
oddball's Avatar
Mine is the earlier unit with three circuits. That's the later year with two circuits. They had a different usage (hydraulic driven radiator fan) in the first generation. So I have one cooler for engine, tranny and power steering. With separate circuits. It's not one huge cooler just for transmission.
Retro, the problem is silicone will break down in presence of petroleum products. An OEM application probably has a liner or different formulation.
My favorite parts guy found a Gates unicoil covered in dust. Giving that a try. It's the one for 3/8" hose, but is actually a bit large for this hose. I also got the Gates 3/8" elbow, but it is surprisingly small and flimsy.
oddball is offline
Old November 16th, 2016, 07:02 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Great find Sir Padavano. Looks like they may have the 90* bypass hose in this reinforced material for our Olds engines. Whats offered today is nothing like the OEM spec hoses. The new repro stuff is thin wall and bulges with RPM, new out of the box. I was forced to put a good 30 year old bypass hose on a newly detailed engine for fear of the new one bursting. The Repro hose clamps lack significant resolution to apply correct clamping force. The repro clamps work great on the OEM hose. But do not provide enough clamping force on the new junk....similar to your Deltas front shocks in which new parts that dont fit!
droldsmorland is online now
Old November 16th, 2016, 09:30 AM
oddball's Avatar
That was a good hint. Looks like that hose is a 5/8" though. Would've been the perfect part at 3/8".
oddball is offline
Old November 16th, 2016, 09:52 AM
Is there enough room to use a metal elbow and a short section of straight hose? Not the prettiest solution, but it meets your needs if there's room.
Old November 16th, 2016, 01:26 PM
m371961's Avatar
And you can get brass barb to barb 90 degree ells at McMaster Carr.
m371961 is offline
Old November 16th, 2016, 04:04 PM
Yellowstatue's Avatar
There is also a wire coil that you slip over the hose. It's several inches long and comes in different sizes for the different hoses.
Yellowstatue is offline
Octania
July 16th, 2015 05:21 PM
Octania
September 17th, 2014 05:11 PM
WMACHINES
August 3rd, 2014 12:24 PM
gerk
January 11th, 2014 02:40 PM
jensenracing77
July 29th, 2012 07:53 AM
Quick Reply: Odd part search: reinforced 90deg hose bend
