Motor mount bolts
OK, I pulled these from parts cars so there's a chance they've been changed over the years. But they fit and look correct. The two that attach the motor mount to the side of the block are 7/16" bolts and are 1 inch long. The threads are 14 per inch which I think is a common pitch. The three bolts that hold the metal perch to the frame cross member are 3/8" bolts and 1 inch long. These have a nut with a lock washer on the engine side of the cross member. Let me know if you need anything else Bruce.
John
John
