i got the car to run after 10 years sitting..
ok i got the olds 98 to fire up today...but i have a small problem first. what king of rodchester carb is on this car its a 1962 olds 98.. and second...the carb leaks alot on the front right side of it when your stand in front of the car...its leaking out a plunger or somethin....it has a rubber groomet arround it....what is this called so that i can figure out how to stop the leak... thanks for any help...
Should be a Rochester 4GC.
My 4GC had the same problem - it's from the rubber boot getting too old and maybe exposure to ethanol in gas, etc. You can get a new carb kit at Napa and it should have the rubber plunger piece. Worth saving the rest of the kit and rebuilding the carb as well.
You won't have to remove too many screws to replace the boot itself.
You can view the pages of the manual for that carb here:
http://www.oldcarmanualproject.com/m...eMan/index.htm
Same thing happened to me and I had to buy another kit! The Napa kit had the boot inside and the one from Fusick didn't.
Officially called "Boot - Pump Plunger" here on this page:
http://www.tocmp.com/manuals/Carbs/R...G_0014_jpg.htm
StickW31
September 28th, 2012 05:22 PM
mryoung4815
August 19th, 2011 11:51 AM
